So, I built my first PC a few months ago and I just realized that my PSU fan is running full speed all the time. It does so the instant I turn on the pc and it runs constantly at the same speed.
It’s a brand-new Corsair VS650 and I am only running a Ryzen 1600 with a GTX 1060.
Is there any way to control the PSU fan or is it normal that the PSU is the loudest part of a pc?
Also, how do I monitor my PSU fan to validate what I am hearing?
https://linustechtips.com/topic/1006541-loud-psu-fan/
If it is running abnormally, see if it is under warranty still, if it is, seek a replacement.
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
https://linustechtips.com/topic/1006541-loud-psu-fan/#findComment-12063952
3 minutes ago, hnnbsch said:
It is still under warranty but I don't have enough experience to know it is runniung abnormally. How can i monitor psu fan speeds and what would be abnormal?
Did it suddenly become louder than it had been previously
https://linustechtips.com/topic/1006541-loud-psu-fan/#findComment-12063976
1 hour ago, seon123 said:
You can't control the fan RPM, and it should not be the loudest part of the PC. Full speed is 2200RPM.
Running the fan at full speed is a failsafe for a broken temperature sensor. RMA it.
How can I monitor the exact RPM my PSU fan is running?
https://linustechtips.com/topic/1006541-loud-psu-fan/#findComment-12064286
 http://a.co/d/8u0WwKW
Yeah you know thought bigger is better ...
Dumb thought.  Since the fan controller is obviously borked, return the PSU and get a 450W instead.
https://linustechtips.com/topic/1006541-loud-psu-fan/#findComment-12064597
