Hi Eveyrone
I am currently building a system and I am uncertain as to which CPU to choose.
The system will be used for office, internet browsing and basic photo editing, not using Photoshop.
I am uncertain as to whether to go with a Ryzen APU or an Intel CPU and which specific version of CPU to go for as well, as there is the potential for the photo editing software used to get more intensive later on, in terms of better software being used.
There has been a request to not have a GPU in the system.
Thank you for your time and i hope you all have a wonderful day! :D
https://linustechtips.com/topic/1006274-overall-build-cpu/
Which specific AMD APU and Intel CPU are you talking about?
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/1006274-overall-build-cpu/#findComment-12061804
What's your budget?
DAEDALUS (2018 Refit) - Processor: AMD Ryzen 5 - 1600 @ 3.7Ghz // Cooler: Cooler Master Hyper 212 LED Turbo Black Edition // Motherboard: Asus RoG Strix B350-F Gaming // Graphics Card: Gigabyte GTX 1060 Windforce 6GB GDDR5 // Memory: 2 x 8GB DDR4 Corsair LPX Vengeance 3000Mhz // Storage: WD Green - 250GB M.2 SATA SSD (Boot Drive and Programs), SanDisk Ultra II 120GB (GTA V), WD Elements 1TB External Drive (Steam Library) // Power Supply: Cooler Master Silent Pro 700W // Case: BeQuiet Silentbase 600 with SilentWings Mk.2 Internal Fans // Peripherals: VicTop Mechanical Gaming Keyboard & VicTsing 7200 DPI Wired Gaming Mouse
PROMETHEUS (2018 Refit) - Processor: Intel Core i5-3470 @ 3.2Ghz // Cooler: Cooler Master 212 EVO // Motherboard: Foxconn 2ABF // Graphics Card: ATI Radeon HD 5450 (For Diagnostic Testing Only) // Memory: 2 x 4GB DDR3 Mushkin Memory // Storage: 10TB of Various Storage Drives // Power Supply: Corsair 600W // Case: Bitfenix Nova Midi Tower - Black
SpeedTest Results - Having Trouble Finding a Decent PSU? - Check the PSU Tier List!
https://linustechtips.com/topic/1006274-overall-build-cpu/#findComment-12061805
I guess GPU means graphics card here? Because even Intel's shoddy integrated graphics is a GPU. A modern system without GPU (we're talking way back till CPU handled graphics) won't be able to display anything directly, resembling a server hooked up for remote access (excluding the remote access part).
but really, that requirement itself kills performance drastically. Photo editing I assume means Adobe products? Those heavily rely on CUDA acceleration, to the point that even a mid range CPU like the 8400 with a GTX 1050 can beat an 8700k with iGPU.
Desktop benching:
https://linustechtips.com/topic/1006274-overall-build-cpu/#findComment-12061864
Can you specify the work load? you might actually need no more than a very simple h310 + i3 8100 + 8gb memory combo.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/1006274-overall-build-cpu/#findComment-12061911
For just small things like Word, Office, Internet, etc..(you could easily do all at once) I would go AMD and get the 2200G or the 2400G if you want to make sure you have the necessary power to do a little more. Plus those chips have way better integrated graphics built in, than Intel does. I literally just built a computer as a christmas gift using the 2200G and ended up using it in my personal build as I had to wait for my GPU (not integrated) to arrive before I could use my 2600X. It actually did everything I needed it to, although it was running at close to 100%, not that I could tell without monitoring it. And that's using Photoshop, browsing the web and having a few other programs open as well. The 2400G would probably perform pretty damn well for basic users that don't do any video editing or anything serious, plus it has even better graphics than the 2200G.
That's my experience, good luck!
Did I mention I even played Crossout on Steam at 1440p on my 4k screen with the 2200g, thanks to freesync it worked without a problem.
Ryzen 3800X + MEG ACE w/ Radeon VII + 3733 c14 Trident Z RGB in a Custom Loop powered by Seasonic Prime Ultra Titanium
PSU Tier List | Motherboard Tier List | My Build
https://linustechtips.com/topic/1006274-overall-build-cpu/#findComment-12061963
