Need help with ram clearance
You could get the noctua NH-D15 because it has movable fans
Primary PC:
PSU tier list
How many watts do I need?
Eh, the hyper x predator ram is very tall, I don't think you could move the fan out of the way enough while still fitting in a mid-tower case.
You could buy the NH-D15S, which is the single fan version. Or just.... you know... not install the 2nd fan.
What about aio cooler with good performance around 90$ ?
Might want to go ask the "water cooling" section of the forum. We don't deal with liquids here. ;)
That said, I don't think you'll find an AIO around $90 that will sufficiently cool your CPU.
5 minutes ago, issawo said:
so you are sayin there is no way i fit 4 ram slots with dr 4
Here, let me do the research for you.
Dark Rock Pro has a ram clearance of 40mm according to the dimensions.
https://www.bequiet.com/admin/ImageServer.php?ID=3c506a15636@be-quiet.net&rand=aacb5c72365228152b595775b5d7b78b&lang=1&force=true&download=true&omitPreview=true
The hyper x predator ram has a height of 42.2 mm.
https://www.hyperxgaming.com/us/memory/predator-ddr4
You could very likely just move the fan up 2 mm and be fine using all 4 slots. Or buy shorter ram.
H100i might do it
Primary PC:
PSU tier list
Pretty much every cooler has movable fan. Thats not the issue. Main issue with cooler compatibility is cooler fins extending over RAM slots.
With non-pro you can fit all 4. And only thing you need to do is to move fan to other side as pull.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
The fan will block the first ram slot. If you move the fan to the other side in pull, it should fit fine but performance will be slightly worse.
There might be a better option available. Where are you shopping / located?
I will always recommend the Thermalright Le Grand Macho RT as it doesn't have any RAM clearance issue for the same performance to NH-D15, and it's less stress to think about performance by moving the fan from here to there, lift the fan by this high because the RAMs are this high and the clearance is that high.
Le Grand Macho RT will just simply plug-and-play rather than plug-and-pray.
My system specs:
CPU: Intel Core i7-8700K, 5GHz Delidded LM || CPU Cooler: Noctua NH-C14S w/ NF-A15 & NF-A14 Chromax fans in push-pull cofiguration || Motherboard: MSI Z370i Gaming Pro Carbon AC || RAM: Corsair Vengeance LPX DDR4 2x8Gb 2666 || GPU: EVGA GTX 1060 6Gb FTW2+ DT || Storage: Samsung 860 Evo M.2 SATA SSD 250Gb, 2x 2.5" HDDs 1Tb & 500Gb || ODD: 9mm Slim DVD RW || PSU: Corsair SF600 80+ Platinum || Case: Cougar QBX + 1x Noctua NF-R8 front intake + 2x Noctua NF-F12 iPPC top exhaust + Cougar stock 92mm DC fan rear exhaust || Monitor: ASUS VG248QE || Keyboard: Ducky One 2 Mini Cherry MX Red || Mouse: Logitech G703 || Audio: Corsair HS70 Wireless || Other: XBox One S Controler
My build logs:
Then be prepare for this kind of risk. This is not always happen but, you have to be consequent to any of your choice and decision with all the risks that follows.
My system specs:
My build logs:
