Your post is very vague. You need to tell us when did this problem start, how long has it been going on for. You also need to tell us what equipment you're using..
https://linustechtips.com/topic/1005968-need-help/#findComment-12060025
11 hours ago, The Lone Dark said:
So i have been having an issue where my Ethernet cuts in an out every so often, idk what it is or how to fix it can anyone help??
Here is what we need, does the PC say that your disconnected from Ethernet or does it say your Internet connection is limited?
Are other devices affected? Such as other computer, phones, tablet, etc?
What are you doing at the time of disconnection?
What kind of equipment are you using?
https://linustechtips.com/topic/1005968-need-help/#findComment-12060322
