Hi people of LTT forum. I just wanted to ask if it would be wise to spend 15 on this fan and  thing to get better temps. This would be attached to the bottom of the case (intake). I have a Tempest 210 (stock fans still installed) with 2 120mm fans in the front. Would it help temps at all if there was some extra fan taking in more air for positive air flow? You can post other fan suggestions under 15 USD dollars. My gpu (Shappire 7870) hits high 70's while burn testing and my Cpu never gets that hot at all. Well any help is appreciated and have a good day.
CPU-- AMD FX-8320 (Stock), Motherboard-- ASUS M5A99FX PRO R 2.0, RAM-- Team 8gb 1600Mhz, GPU-- Sapphire 7870 GHz with OC Edition, Case-- NZXT Tempest 210, PSU-- Corsair CX600m, HDD, 1tb Seagate & 2tb WD External, Monitor-- Dell S2240M IPS Display, Keyboard/Mouse-- Some Logitech keyboard and some Dell mouse, Speakers-- Logitech Z533
https://linustechtips.com/topic/100556-bottom-intake-fan/
I'd say there's no reason for it with the temps you're getting.
https://linustechtips.com/topic/100556-bottom-intake-fan/#findComment-1345403
Having one extra fan on bottom won't bring more than 1-3C lower temps to that system. That slot will cool mainly you GPU and it gets enough from front already. Unless you have populated all hdd slots with stuff that is blocking air flow. In that case extra cooling would help more.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/100556-bottom-intake-fan/#findComment-1347865
Well thanks for answering. Have a good day/ night
https://linustechtips.com/topic/100556-bottom-intake-fan/#findComment-1348267
