I need some help on a pc build for 3D art.
Using it mainly for Blender 2.8, Eevee (realtime renderer), Keyshot, Octane renderer, Photoshop, etc.
My brother gave me a few starting parts.
I already have a monitor, huge case with motherboard, and a thousand case fans.
The motherboard is an Asus Z170-A.
So all the components would need to be compatible with it.
Looks like I still need:
Power supply
Graphics card (nvidia GeForce)
CPU
RAM
SSD (250-500GB)
I can always add another 1TB HD later.
I'm trying to get back into 3D, so I'd like to keep the cost on the low end...
$400-600 USD.
Yeah, I know that's asking a lot for a little.
Any help would be very appreciated.
https://linustechtips.com/topic/1004502-build-help-for-3d-art/
Having built 40 + systems (13 my own the rest for friends, family etc) Your going to have to go heavy used
I would rather agree on what we share, than fight on what we don't. - Myself
FULL PC SPECS ON PROFILE https://linustechtips.com/main/profile/454099-thinkfreely/
https://linustechtips.com/topic/1004502-build-help-for-3d-art/#findComment-12046169
This is what i came up with.
Because those programs mostly use the cpu? And don't use much of CUDA acceleration, i went all out on the cpu, and added a meh gpu.
Also i threw out your old motherboard, it is pretty much useless, as you can only put a i7 6700k and i7 7700k in it, which are 4c/8t, and the price of 6700k and 7700k are just absurd, even when they are used.  An AMD 6c/12c is cheaper and performs better.
I only see your reply if you @ me.
https://linustechtips.com/topic/1004502-build-help-for-3d-art/#findComment-12046199
That's going to be pretty tough with a Z170 board. I'm not really familiar with the programs so I won't be able to put the best build together, but I'm pretty sure that anything with the Z170 will exceed your price limit.
Skyggeis Specs:
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor
CPU Cooler: CRYORIG H5 Ultimate 76.0 CFM CPU Cooler
Motherboard: MSI Z170A SLI PLUS ATX LGA1151 Motherboard
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000
Storage: Samsung 850 EVO 250GB 2.5" Solid State Drive
Storage: Western Digital Caviar Blue 1TB 3.5" Hard Drive
Video Card: Zotac GeForce GTX 1070 8GB AMP! Extreme
Case: Phanteks ECLIPSE P400S ATX Mid Tower Case Satin Black
PSU: Corsair RMx 750W 80+ Gold Certified Fully-Modular PSU
WiFi Card: Gigabyte GC-WB867D-I REV 4.2
Case Fan: Aerocool DS 140mm Black 93.4 CFM
Other: Coolermaster VGA Holder
Other: Phanteks LED Strip 1M
Other: Phanteks Fan Splitter
Monitor: Dell S2716DG
https://linustechtips.com/topic/1004502-build-help-for-3d-art/#findComment-12046202
Power supply
CPU
RAM
SSD (250-500GB)
tier c+ (450 watts is enough on here, but nothing wrong with 550w)
Why nvidia? my recommendations would be the following (from low to high end, nvidia left, amd right)
1060/580
970/390(x)
1070 ti/vega 56
1080 ti/ vega 64
quadro/firepro
I would say a second hand 7700k or 6700k
16 gigs minimum, dual channel
mx500 or 860 evo are great sata ssd's for a fair price
https://linustechtips.com/topic/1004502-build-help-for-3d-art/#findComment-12046211
Thinkfreely -
Are there reliable online sellers of used parts? Parts that are actually tested and working properly?
Origami Cactus -
Thanks for the suggestions!!
Looking into it more, you might be right about dumping the current motherboard.
I also was able to snag a 600w PSU from friend today, so that's one less thing to worry about.
As for CPU vs GPU intensive programs - unfortunately it's a mix of both. Renderers like Keyshot are cpu-based. But Blender's Cycles and Eevee renderers are gpu-based, along with Octane. Maybe it makes sense to start with a really good CPU and plan on upgrading the gpu later? Would be nice to get something that could handle the realtime rendering of Eevee at the start though.
rphawks -
Yeah, as Origami Cactus mentioned I might just need to get a new board.
LukeSavenije -
Good news is that I just got a 600w PSU. All set there... if it's functional.
The reason for nvidia was because I was under the assumption that Blender only played nicely with cuda. At least that's what it seemed like a few years ago. It looks like they've updated things in 2.9 and now support OpenCL as well, so I guess a geforce card isn't mandatory anymore.
Thanks for the suggestions.
https://linustechtips.com/topic/1004502-build-help-for-3d-art/#findComment-12047010
