Hi everyone!
I'm looking for a bit of support regarding water cooling my graphics card. Problem so far is, I'm struggling to figure out what block I need to be going for. I have the MSI GTX 1080Ti Armor OC Edition, which at the time was a great choice, but looking at the difficulty of getting a water block, it's no longer an amazing choice.
What I need help with is the following; I have found the following block from EK and I want to know if it will be compatible with my card, if not, can you amazing people offer any suggestions?
https://www.ekwb.com/shop/ek-fc1080-gtx-ti-tf6-acetal-nickel
Note - My card does not have any form of "backplate." I also plan to use this in the EK A240G water cooling loop (from what I understand, there shouldn't be any galvanic corrosion between the nickel and aluminium right?
Any and all help is extremely appreciated guys.
Cheers,
Flinty
https://linustechtips.com/topic/1004485-graphics-card-cooling-problems/
pretty sure the armor card shares the PCB with the Gaming X?
Builds:
3 minutes ago, Flinty said:
Hi everyone!
Cheers,
Flinty
The MSI GTX 1080Ti Armor uses the same PCB layout as the Gaming X cards as confirmed in this article from Gamers Nexus. So anything that is slated to work with a Gaming X card from MSI will work, the founders will NOT.
https://www.gamersnexus.net/hwreviews/2927-msi-1080ti-armor-review-high-temps?showall=1
Community Standards
"Beast Mode"
Dedicated Streaming Rig
Note that there are 2 variants of the gaming X card, with different PCB's
So look at the EX compatibility chart, and compare your board with the 2 different gaming X variants.
CPU: 2x E5620 - GPU: 2x GTX660 - RAM: 64gb DDR3 ECC - Mobo: Z800 OEM - Storage:1TB WD Green - 256gb - Micron C400 250gb - 850 EVO - 512gb 850 PRO
Monitors: 3x HP ZR2440W - Keyboard: G710 MX Blue - Mouse: MX Master
Keep up the good tone and stay classyxD
Hi everyone, thanks for the rapid response.
Upon further inspection, the water block matches the Gaming X perfectly fine, what I now need to know is the following, is a backplate needed? Also, will the nickel cause any issues with the all aluminium A240G kit?
Thanks Again,
Flinty
Nickel and aluminium should be fine
wouldnt do that myself. Also are you playing to run the cpu block and cool both components with that rad?
lol, guess that depends on the temps you want.
