Ryzen 5 2600 stock cooler OC Question
Solved by Fasauceome,
17 minutes ago, Scorpio 72472 said:I didn't get it. Sorry. Could you please explain
Thank you
So AMD uses a software called XFR, I accidentally called it XMP. XFR automatically boosts your CPU frequency if it's cool enough, and the wraith stealth can get 3.8 GHz on all cores with the Ryzen 5 2600 in a good climate. If you're overclocking on the wraith stealth, you can probably get all cores to 3.8, so it's a good cooler if you leave it up to software and have small goals, but if you want above 4.0GHz, a better cooler is needed.
