Wifi problems
Go to solution Solved by mynameisjuan,
I used to have the same mobo. You need to plug in the wifi antennas to get a strong enough signal.
Hi I have wifi problems with my PC basically i try to connect to wifi but it doesn't work it says secured, no internet (Windows)
spec
mobo asus p8z77-v pro
Intel core i7-3770k
32 gig ddr3 1400mhz
radeon Hd 7970 dc2 3gb gddr5 by asus
Windows says my wifi adapter is Qualcm atheros AR9485
but I think my motherboard has wifi and it's not there like WTF HELP idk what to dO
https://linustechtips.com/topic/1003195-wifi-problems/
