Yep, just sign in and it'll walk you through it on the new install when you go to activate it again
https://linustechtips.com/topic/1003172-help-with-activation/#findComment-12033892
Is it a digital license or retail? Yes. Is it OEM? It's not supposed to.
Main Gaming and Streaming PC: http://pcpartpicker.com/user/Vinsinity/saved/TjwVnQ
Ultrabook and College Laptop:
XPS 13 9350:
i5-6200U
8GB RAM
Samsung PM951 250GB M.2 Solid State Drive
Workstation Laptop:
Sager NP8672 (P670SG):
i7-4720HQ
32GB (4 x 8GB) CORSAIR Vengeance Performance
Samsung 850 EVO 250GB M.2 Solid State Drive (Boot Drive)
Samsung 950 PRO 512GB M.2 Solid State Drive (Video Drive)
Crucial MX100 250GB 2.5" Solid State Drive (Secondary SDD Storage)
Western Digital (Blue or Black) 1TB 2.5" 7200RPM Internal Hard Drive (Storage Drive)
GeForce GTX 980M 4G
https://linustechtips.com/topic/1003172-help-with-activation/#findComment-12033895
https://linustechtips.com/topic/1003172-help-with-activation/#findComment-12033922
That no longer applies to windows 10.
Also in previous versions of windows too sometimes.
https://linustechtips.com/topic/1003172-help-with-activation/#findComment-12033924
12 hours ago, Randomizer23 said:
What does oem mean
It means original equipment manufacturer. Rebuilt systems like Dell will use these types of licenses. This is also a type of license you could buy from places like Amazon. Retails allows you to switch hardware components as much as you want. OEM is supposed to only be used once and usually linked to the motherboard. I will only say what is legal.
XPS 13 9350:
i5-6200U
8GB RAM
Workstation Laptop:
i7-4720HQ
GeForce GTX 980M 4G
https://linustechtips.com/topic/1003172-help-with-activation/#findComment-12035908
