Posted November 29, 2018 I am simply looking for the cpu cooler that will keep my cpu, a Ryzen 7 2700, the coolest. It can be either an aio or air cooler and I just need it to be under $100. Aesthetics and noise level are important to me, but not nearly as much as raw performance. Link to comment https://linustechtips.com/topic/1002077-best-cpu-cooler/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 29, 2018 I'll say the nh-d15 and dark rock pro 4 are great choises. But on a cheaper side you can also get a Artic freezer 33 esports, depending on what version you get it's between 35 and 50 bucks Link to comment https://linustechtips.com/topic/1002077-best-cpu-cooler/#findComment-12020769 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 29, 2018 Just now, LukeSavenije said: I'll say the nh-d15 and dark rock pro 4 are great choises. But on a cheaper side you can also get a Artic freezer 33 esports, depending on what version you get it's between 35 and 50 bucks I second the D15 "Although there's a problem on the horizon; there's no horizon." - K-2SO Link to comment https://linustechtips.com/topic/1002077-best-cpu-cooler/#findComment-12020774 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 29, 2018 He theres this really good aio from cooler master, it also has rgb https://www.amazon.com/dp/B079K244KZ/ref=sspa_dk_detail_1?psc=1&pd_rd_i=B079K244KZ&pf_rd_m=ATVPDKIKX0DER&pf_rd_p=f0dedbe2-13c8-4136-a746-4398ed93cf0f&pd_rd_wg=mjG9a&pf_rd_r=P0NBPR0X88Y30S2T5170&pf_rd_s=desktop-dp-sims&pf_rd_t=40701&pd_rd_w=eXECC&pf_rd_i=desktop-dp-sims&pd_rd_r=0e2be4cd-f3e8-11e8-b8bf-2d5ac68107a8 Link to comment https://linustechtips.com/topic/1002077-best-cpu-cooler/#findComment-12020781 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 29, 2018 It's hands down the NH-D15. That thing is monstrous, I don't think anyone makes a bigger tower cooler. I WILL find your ITX build thread, and I WILL recommend the SIlverstone Sugo SG13B Primary PC: i7 8086k - EVGA Z370 Classified K - G.Skill Trident Z RGB - WD SN750 - Jedi Order Titan Xp - Hyper 212 Black (with RGB Riing flair) - EVGA G3 650W - dual booting Windows 11 and Fedora Linux - Black and green theme, Razer brainwashed me. Draws 400 watts under max load, for reference. PSU tier list How many watts do I need? PSU misconceptions, protections explained, group reg is bad Link to comment https://linustechtips.com/topic/1002077-best-cpu-cooler/#findComment-12020866 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 29, 2018 NH-D15 ..its "The King of the air coolers" for a reason The only way to beat it is to get a 280mm AIO (which barely does better) or a 360mm AIO. But they be more expensive. CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)| VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White | Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans | Link to comment https://linustechtips.com/topic/1002077-best-cpu-cooler/#findComment-12021152 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 29, 2018 Author I am simply looking for the (aio) cpu cooler that will keep my cpu, a Ryzen 7 2700, the coolest. The only catch is it has to be 120mm and less than $100. Aesthetics and noise level are important to me, but not nearly as much as raw performance. RGB would be a welcoming feature. Link to comment https://linustechtips.com/topic/1002077-best-cpu-cooler/#findComment-12021346 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 29, 2018 Cheapest https://www.amazon.com/Cooler-Master-MasterLiquid-Chamber-MLA-D24M-A18PC-R1/dp/B07CRGC899/ref=sr_1_4?s=pc&ie=UTF8&qid=1543513703&sr=1-4&keywords=aio Coolest https://www.amazon.com/CORSAIR-Radiator-Advanced-Lighting-Software/dp/B019955W7C/ref=sr_1_fkmr1_2?s=electronics&ie=UTF8&qid=1543513779&sr=1-2-fkmr1&keywords=cooler+master+280mm Might have to buy the AM4 brackett for either separately, didn't double check. I would rather agree on what we share, than fight on what we don't. - Myself FULL PC SPECS ON PROFILE https://linustechtips.com/main/profile/454099-thinkfreely/ Link to comment https://linustechtips.com/topic/1002077-best-cpu-cooler/#findComment-12021369 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 29, 2018 How does the Corsair H80i V2 look to you? I WILL find your ITX build thread, and I WILL recommend the SIlverstone Sugo SG13B Primary PC: i7 8086k - EVGA Z370 Classified K - G.Skill Trident Z RGB - WD SN750 - Jedi Order Titan Xp - Hyper 212 Black (with RGB Riing flair) - EVGA G3 650W - dual booting Windows 11 and Fedora Linux - Black and green theme, Razer brainwashed me. Draws 400 watts under max load, for reference. PSU tier list How many watts do I need? PSU misconceptions, protections explained, group reg is bad Link to comment https://linustechtips.com/topic/1002077-best-cpu-cooler/#findComment-12021376 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 29, 2018 Author I am looking for an aio, preferably rgb but I can do without, and I don’t know which to buy. I was looking at CoolerMasters LC120E and ML120L but I dont see much difference. Link to comment https://linustechtips.com/topic/1002077-best-cpu-cooler/#findComment-12021424 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 29, 2018 Author 11 minutes ago, Thinkfreely said: Cheapest https://www.amazon.com/Cooler-Master-MasterLiquid-Chamber-MLA-D24M-A18PC-R1/dp/B07CRGC899/ref=sr_1_4?s=pc&ie=UTF8&qid=1543513703&sr=1-4&keywords=aio Coolest https://www.amazon.com/CORSAIR-Radiator-Advanced-Lighting-Software/dp/B019955W7C/ref=sr_1_fkmr1_2?s=electronics&ie=UTF8&qid=1543513779&sr=1-2-fkmr1&keywords=cooler+master+280mm Might have to buy the AM4 brackett for either separately, didn't double check. I need a 120mm though Link to comment https://linustechtips.com/topic/1002077-best-cpu-cooler/#findComment-12021426 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 29, 2018 Author 11 minutes ago, fasauceome said: How does the Corsair H80i V2 look to you? It looks pretty good but a tad expensive Link to comment https://linustechtips.com/topic/1002077-best-cpu-cooler/#findComment-12021433 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 29, 2018 1 minute ago, Mofro1122 said: I need a 120mm though Cheapest https://www.amazon.com/Cooler-Master-MasterLiquid-Chamber-MLA-D12M-A18PC-R1/dp/B07CRG8X69/ref=sr_1_7?ie=UTF8&qid=1543514545&sr=8-7&keywords=120mm+aio Coolest https://www.amazon.com/CORSAIR-Hydro-Liquid-Cooler-Radiator/dp/B019954Y2Q/ref=sr_1_2?ie=UTF8&qid=1543514579&sr=8-2&keywords=120mm%2Baio&th=1 I would rather agree on what we share, than fight on what we don't. - Myself FULL PC SPECS ON PROFILE https://linustechtips.com/main/profile/454099-thinkfreely/ Link to comment https://linustechtips.com/topic/1002077-best-cpu-cooler/#findComment-12021439 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 29, 2018 120mm AIO's aren't really worth it. I used to have an H80i v2 and I switched back to my H212 EVO. The H80i performed just a little better, was way louder and made my case so crammed that the GPU temps rose by 5C. Get some decent modern air cooler like an Arctic Freezer 33 esports or A Dark rock 4. Link to comment https://linustechtips.com/topic/1002077-best-cpu-cooler/#findComment-12021453 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 29, 2018 the fan and CPU cooling block are both different... but really, cheap AIO like these are failures as far as performance's concerned. CPU: i7-2600K 4751MHz 1.44V (software) --> 1.47V at the back of the socket Motherboard: Asrock Z77 Extreme4 (BCLK: 103.3MHz) CPU Cooler: Noctua NH-D15 RAM: Adata XPG 2x8GB DDR3 (XMP: 2133MHz 10-11-11-30 CR2, custom: 2203MHz 10-11-10-26 CR1 tRFC:230 tREFI:14000) GPU: Asus GTX 1070 Dual (Super Jetstream vbios, +70(2025-2088MHz)/+400(8.8Gbps)) SSD: Samsung 840 Pro 256GB (main boot drive), Transcend SSD370 128GB PSU: Seasonic X-660 80+ Gold Case: Antec P110 Silent, 5 intakes 1 exhaust Monitor: AOC G2460PF 1080p 144Hz (150Hz max w/ DP, 121Hz max w/ HDMI) TN panel Keyboard: Logitech G610 Orion (Cherry MX Blue) with SteelSeries Apex M260 keycaps Mouse: BenQ Zowie FK1 Model: HP Omen 17 17-an110ca CPU: i7-8750H (0.125V core & cache, 50mV SA undervolt) GPU: GTX 1060 6GB Mobile (+80/+450, 1650MHz~1750MHz 0.78V~0.85V) RAM: 8+8GB DDR4-2400 18-17-17-39 2T Storage: HP EX920 1TB PCIe x4 M.2 SSD + Crucial MX500 1TB 2.5" SATA SSD, 128GB Toshiba PCIe x2 M.2 SSD (KBG30ZMV128G) gone cooking externally, 1TB Seagate 7200RPM 2.5" HDD (ST1000LM049-2GH172) left outside Monitor: 1080p 126Hz IPS G-sync Desktop benching: Cinebench R15 Single thread:168 Multi-thread: 833 SuperPi (v1.5 from Techpowerup, PI value output) 16K: 0.100s 1M: 8.255s 32M: 7m 45.93s Link to comment https://linustechtips.com/topic/1002077-best-cpu-cooler/#findComment-12021494 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 29, 2018 Author The problem is that huge air coolers like the Noctua nh-15 are simply too ugly to be put in a case with a glass panel and it is also nearly $100 Link to comment https://linustechtips.com/topic/1002077-best-cpu-cooler/#findComment-12021535 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 29, 2018 Author The LC120E is $35 on Amazon, so how do you think this will compare to a 212 evo. Link to comment https://linustechtips.com/topic/1002077-best-cpu-cooler/#findComment-12021541 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 29, 2018 Author 11 minutes ago, Jurrunio said: the fan and CPU cooling block are both different... but really, cheap AIO like these are failures as far as performance's concerned. The LC120E is $35 on Amazon, so how do you think this will compare to a 212 evo. Link to comment https://linustechtips.com/topic/1002077-best-cpu-cooler/#findComment-12021551 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 29, 2018 if your going to go with a AIO , get a 280mm rad or 360mm rad one. 240 and below are not worth it. CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)| VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White | Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans | Link to comment https://linustechtips.com/topic/1002077-best-cpu-cooler/#findComment-12021555 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 29, 2018 Author 1 minute ago, SolarNova said: if your going to go with a AIO , get a 280mm rad or 360mm rad one. 240 and below are not worth it. S 1 minute ago, SolarNova said: if your going to go with a AIO , get a 280mm rad or 360mm rad one. 240 and below are not worth it. So which air cooler is the best that’s under $80 and is not completely ugly Link to comment https://linustechtips.com/topic/1002077-best-cpu-cooler/#findComment-12021568 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 29, 2018 Author I am simply looking for the cpu cooler that will keep my cpu, a Ryzen 7 2700, the coolest. It can be either an aio or air cooler and I just need it to be under $80. Aesthetics need to be presentable through a side panel. So no Noctua nh-15. It doesn’t need to be rgb or anything black is fine Link to comment https://linustechtips.com/topic/1002077-best-cpu-cooler/#findComment-12021583 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 29, 2018 dark rock pro Link to comment https://linustechtips.com/topic/1002077-best-cpu-cooler/#findComment-12021594 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 29, 2018 4 minutes ago, Mofro1122 said: I am simply looking for the cpu cooler that will keep my cpu, a Ryzen 7 2700, the coolest. It can be either an aio or air cooler and I just need it to be under $80. Aesthetics need to be presentable through a side panel. So no Noctua nh-15. It doesn’t need to be rgb or anything black is fine Be Quiet Dark Rock 4 Link to comment https://linustechtips.com/topic/1002077-best-cpu-cooler/#findComment-12021604 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 29, 2018 Just now, gabrielgames said: Be Quiet Dark Rock 4 You will be happy with this cooler being all black and having a 200w tdp 74.90 USD Link to comment https://linustechtips.com/topic/1002077-best-cpu-cooler/#findComment-12021608 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 29, 2018 The wraith cooler that your cpu got is already good. With after market heatsink it would only be better like 3-5c at best! Such a waste of money i think, for $80 you can have something else. Ryzen 5700g @ 4.4ghz all cores | Asrock B550M Steel Legend | 3060 | 2x 16gb Micron E 2666 @ 4200mhz cl16 | 500gb WD SN750 | 12 TB HDD | Deepcool Gammax 400 w/ 2 delta 4000rpm push pull | Antec Neo Eco Zen 500w Link to comment https://linustechtips.com/topic/1002077-best-cpu-cooler/#findComment-12021624 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
