Hi there, I'm planning to build a PC for my programming software and normal browsing. My budget is around 850 USD. Prolly gonna run 2 monitors@1080p at most and maybe run Ubuntu and/or Windows 10. I am not sure how good a PC I need or what are the minimum requirements for a smooth user experience.
Programming as in enterprise-level apps? Or just small personal stuff, cuz you can do that on like an i3 and run the igpu.
Ryzen 5 1600 @ 3.9 Ghz  | Gigabyte AB350M Gaming 3 |  PaliT GTX 1050Ti  |  8gb Kingston HyperX Fury @ 2933 Mhz  |  Corsair CX550m  |  1 TB WD Blue HDD
Inside some old case I found lying around.
Are you going to be doing any gaming? If not get a CPU with an iGPU (Ryzen 2400G/Intel i5) and you can save a but load of money. Otherwise yeah you could get a Ryzen 2600 and a very very cheap GPU (whatever the cheapest you can find on the retailers site, something like a GT 710, usually $30-40).
i would say a gt 1030 at least.. a 710 is utter doodoo
✧・゚: *✧・゚:*  Quote for a reply  *:・゚✧*:・゚✧
✧・゚: *✧・゚:*   Ask for discord   *:・゚✧*:・゚✧
Just now, schwellmo92 said:
He hasn't said he needs to play any games, a cheap-ass 710 is fine.
ik but for literally less than $50 more he can get a gt 1030 and considering the budget is $850 im sure he can throw an extra $50 at a much better gpu
For JUST programming (no gaming or anything), then honestly there really isn't much for requirements. I'm a software engineer who works at a huge enterprise software company, and I just use a laptop for all my development.
There are things in engineering that can benefit from a beefy system, like compiling a huge codebase, but:
  1. They aren't usually something a new programmer would have to even think about
  2. They are almost always done on remote build systems, with only small pieces actually needing to be worked with locally
If this gives you any indication, lots of people actually develop in VMs. A typical example might be you have a windows system, and have to work on a rails server app. Since ruby doesn't run natively in windows, you'd boot up a linux VM to developer/troubleshoot your rails server. That fact that you can program through a VM running in a medium grade laptop hopefully illustrates the idea that power isn't really a super important thing in coding. Save your money and don't overbuild a PC if ALL you want is a programming environment.
Gaming build:
CPU: i7-7700k (5.0ghz, 1.312v)
GPU(s): Asus Strix 1080ti OC (~2063mhz)
Memory: 32GB (4x8) DDR4 G.Skill TridentZ RGB 3000mhz
Motherboard: Asus Prime z270-AR
PSU: Seasonic Prime Titanium 850W
Cooler: Custom water loop (420mm rad + 360mm rad)
Case: Be quiet! Dark base pro 900 (silver)
Primary storage: Samsung 960 evo m.2 SSD (500gb)
Secondary storage: Samsung 850 evo SSD (250gb)
Server build:
OS: Ubuntu server 16.04 LTS (though will probably upgrade to 17.04 for better ryzen support)
CPU: Ryzen R7 1700x
Memory: Ballistix Sport LT 16GB
Motherboard: Asrock B350 m4 pro
PSU: Corsair CX550M
Cooler: Cooler master hyper 212 evo
Storage: 2TB WD Red x1, 128gb OCZ SSD for OS
Case: HAF 932 adv
Or a 750 Ti or any other actually decent gaming card instead of a 1030
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
Except if all he is doing is programming, he might not actually even need a GPU at all so that $50 might be literally wasted. I don't know of any programming environments off the top of my head that use GPU acceleration, outside of video game development.
EDIT: If the programming environment is "data science" then maybe a gpu would be a huge help, BUT if that's the field we're talking about than that's usually going to be actually computed off-machine. "Data scientist who has no remote crunching resources" is a pretty specific case imo.
Gaming build:
Server build:
CPU: Ryzen R7 1700x
PSU: Corsair CX550M
Case: HAF 932 adv
And for $50 more he could get a GTX 1050 which is also much better than the GT 1030, it's a never ending thing. If you don't need the horsepower then no need to go for a 1030, if the time comes when you need a good GPU you could buy something like a 1060+ and he has saved that $50 between the 710 and 1030 (because lets face it - the 1030 isn't exactly stellar either).
I won't be doing any gaming on this. Mostly small scale coding and youtube.
CPU: AMD - Ryzen 5 2400G 3.6 GHz Quad-Core Processor  ($157.99 @ SuperBiiz)
Motherboard: ASRock - B450 Pro4 ATX AM4 Motherboard  ($74.99 @ Newegg Business)
Memory: G.Skill - Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3000 Memory  ($114.99 @ Newegg)
Storage: Samsung - 860 Evo 1 TB 2.5" Solid State Drive  ($127.98 @ Amazon)
Case: NZXT - H500 (Black) ATX Mid Tower Case  ($64.99 @ Newegg)
Power Supply: Corsair - CXM (2015) 450 W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($49.99 @ Newegg)
Total: $590.93
Generated by PCPartPicker 2018-11-28 12:05 EST-0500
Total: $590.93
This is a good build for you :)
If you plan on running many VMs like more than 2 (depending on your dev work), you could add more RAM, swap the CPU for a 2600/2700 and get a very cheap GPU (GT 710).
