Power supply advice
By
Vague
in Power Supplies
in Power Supplies
Solved by MrImnotMLG,
So if i was to get 650W version, would that be good enough for some overclocking head room?
I really don't like the RM series "cables"
I have a similar build in the queue on PCPP that says 472w(at stock) so it should all work fine because overclocking shouldn't use that much more power than stock.
Serendipity1344 ·
Posted in Graphics Cards3 -
1
1
5
1
toxic_worper ·
13
1
voltigeurramon ·
Posted in Troubleshooting2 -
2
