Help me choose the right fan
blik22
Hello everyone, I have a Thermaltake Versa N26 case, and i plan to add two intake fans at the front and keep the stock one at the back as exhaust, the problem is that this case has a grille/mesh where the fans are installed, you can see it in this video , so now i don't know if i have to choose an Air Flow or a Static Pressure fan, I also plan to keep the bottom HDD cage that comes with it.
Thank you
Any fan is fine as long it's not loud
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
I will get a Corsair Air Series 120 QUIET and both AF and SP are available, so if we factor out the noise, what should i get?
@Justux204 unfortunately only the Corsair Air QUIET is available at the local store where i'll build my pc, and only need to confirm if i take the AF or SP
