Using RGB to monitor components usage
hipo5PL
Just came up with an idea of a PC build that would monitor CPU, GPU and RAM usage with help of RGB lighting. Did a quick google search, but I didn't come across anything like it.
Do you know of any RGB CPU coolers or GPUs that could show their usage through colors? :) RAM could show it's allocated memory and all could cycle through green-yellow-red colors under heavy load.
That would make for a first PRACTICAL use of RGB ever - quite an acomplishment :D
780 Lightning had usage load that was shown with LEDs on card.
This is my board...
EVGA have done it too.
January 2015 till February 2017:
  1. http://www.evga.com/articles/00904/EVGA-GeForce-GTX-980-KINGPIN-ACX-2/
  2. http://www.evga.com/articles/00944/EVGA-GeForce-GTX-980-Ti-KINGPIN/
  3. http://www.evga.com/articles/01084/evga-icx/
Precision X has these options for the RGB enabled cards:
  • Static ON
  • Static OFF
  • Demo1
  • Demo2
  • Demo3
  • Demo4
  • PCB Temp
  • GPU Temp
  • Power
  • Graphics
If you dont mind doing a little bit of DIY, my project has you covered: https://linustechtips.com/main/topic/695133-diy-nzxt-hue-so-easy-anyone-could-do-it-update/
Quote or tag if you want me to answer! PM me if you are in a real hurry!
Why do Java developers wear glasses? Because they can't C#!
My Machines:
The Gaming Rig:
-Processor: i5 6600k @4.6GHz
-Graphics: GTX1060 6GB G1 Gaming
-RAM: 2x8GB HyperX DDR4 2133MHz
-Motherboard: Asus Z170-A
-Cooler: Corsair H100i
-PSU: EVGA 650W 80+bronze
-AOC 1080p ultrawide
My good old laptop:
Lenovo T430
-Processor: i7 3520M
-4GB DDR3 1600MHz
-Graphics: intel iGPU :(
-Not even 1080p
I wanted similar thing, tho i didint used leds, instead i decided to use old android phone. And thus i developed application for monitoring system
You can find it at http://withoutcaps.site
It calls "system monitor"
Need extra features? Contact me, i may implement them
  • Static ON
  • Static OFF
  • Demo1
  • Demo2
  • Demo3
  • Demo4
  • PCB Temp
  • GPU Temp
  • Power
  • Graphics
Its weird with precision XOC I only have Static On / Off / Demo 1 / 2 for use with my 1080 hybrid.
Well that's because the 1080 Hybrid does not have the feature set that the K|NGP|N cards do.
AquaComputers farbwerk can do that With software & hardware sensors.
Link: https://shop.aquacomputer.de/product_info.php?products_id=3344&XTCsid=u7driie8ko4jg18gb8sh9748g12vnjno
EVGA has a GPU that colors change based on temp. As for CPU, Theirs RGB CPU waterblocks, Not sure theirs any that will change color based on increasing temp by it self.
You do have AquaComputer Vision Waterblocks which displays the CPU/GPU temp on the waterblocks.
Current Build: Project Frost
Gaming Rig Build: Project Ice Dragon
