Need help migrating OS from 1tb hard drive to 240 gig ssd
2 minutes ago, krish9116 said:the bootloader partition is the one with the windows files right?
It's separate from the C:\ drive, where Windows is. It's not labeled, but it should be a few hundred megabytes.
Just now, krish9116 said:so i need to create a bootable usb if im not wrong ? my issue is that me and my brother share this computer and he has a seperate user id. so i would prefer that these settings are saved. is there an option to create sucha bootable drive?
All of your user profile settings are saved in the account's %APPDATA% folder. If you type this into File Explorer, it'll take you to the directory that you need to back up if you want to save things.
You can also just copy wholesale the C:\Users folder. Though keep in mind that you'll run into permissions gremlins if you do a fresh install and try to transfer the files back.
