Case fans for Corsair Carbide 300R
Solved by acolombo,
I currently have a 300R, I've put two 140mm fans at the front intaking the air, and two at the top exausting the air; also the stock 120mm is still on the rear, I only got rid of the metal screws and used some rubber ones. If you don't know what to choose between SP and AF, AF stands for Air Flow and SP stands for Static Pressure.
For the side panel and the case in general you should use the AF ones, the SP ones are good only for dissipators and radiators, when they are directly mounted against a heat source.
Look at these two videos:
