Monitor help?
Johntheawesomeguy
Hi. I am a complete noob when it comes to monitors. I need I monitor with a fast Hz, good colors, good resolution, and A decent stand. I am trying to find a monitor at around $175. Comment your current monitor, what you think of it, and a link. Or a link to a good monitor that would be good for me for gaming. Thank you so much! BTW this is the second time posting this because I didnt get a lot of feedback last time I posted. Current monitors I am looking at
Broke 14 Year old + No job + Love for Technology = Bad combo :(
What kind of refresh speeds do you need? to get above 60hz you are going to move to a TN panel, and that is where you start to loose color accuracy.
Out of the ones you posted, I would go for Either the AOC one, or the Acer
maybe 75Hz would be nice but for a budget monitor it is hard to get high refresh rate
Qnix, X-Star, and Overlord 2560x1440 monitors are 110Hz and IPS.
Yes, but those are all korean panels, and the OP's budget doesn't allow for a $300 monitor.
