Does this solution work? two AUX speakers do stereo sound
1 hour ago, 5GigaaHertz said:So the two speakers will output audio left and right separately but the sound isnt separated(mono)?
With the mono to stereo adapter it would be like this.
And without the mono to stereo adapter:
According to the AliExpress listing the speaker is stereo but you could use this video to confirm if it is or not.
If you don't hear anything when it's playing the music from right channel, the speaker is mono. You don't need the mono to stereo adapter
If you can hear the audio the whole time and can't locate the drivers, the speaker probably combines stereo signal to one channel. You don't need the mono to stereo adapter
If you can hear the audio coming from different sides of the speaker (the speaker is using different drivers), the speaker is stereo. You need the mono to stereo adapter
