Need help choosing a power supply
23 minutes ago, wegoodtbh said:As far as I am aware the power supply is "okay" for my current build but I would like some flexibility in over clocking. Should I keep my power supply or get another one? And if anyone knows any good power supplies under $100 I'd really appreciate it
I'd go for a CX 550m for a build like this it's a decent PSU with more than enough wattage. And if you can spend a bit more you can get a 5600xt it is on par with the RTX 2060. You get much more performance for your money this way.
So your build would look like this:
Quote
PCPartPicker Part List: https://pcpartpicker.com/list/cjtTk6
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor ($169.99 @ Walmart)
Motherboard: MSI B450 TOMAHAWK MAX ATX AM4 Motherboard ($124.99 @ Best Buy)
Memory: Team T-Force Delta RGB 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory ($72.98 @ Amazon)
Storage: Crucial MX500 1 TB 2.5" Solid State Drive ($114.99 @ Adorama)
Video Card: Gigabyte Radeon RX 5600 XT 6 GB WINDFORCE OC Video Card ($259.99 @ Newegg)
Case: NZXT H510 ATX Mid Tower Case ($69.99 @ Best Buy)
Power Supply: Corsair CXM 550 W 80+ Bronze Certified Semi-modular ATX Power Supply ($79.99 @ Newegg)
Total: $892.92
Generated by PCPartPicker 2020-07-04 15:21 EDT-0400
And looking at your current PSU, it more than enough tbh (between tier B and C, which is enough for the specs of your build) you can keep it and still get the most out of your PC. And don't worry about overclocking, it's not worth putting the effort into it. Your 3600 boosts really aggressively near it's limits anyways, and GPUs have GPU boost which is also pretty aggressive.
