Are there any good RGB Headers to connect a Phanteks P350x and a MSI B450 Tomahawk Max with Mystic Light?
Solved by FriedEngineer,
7 minutes ago, Dan Flame said:I would say in software since im really forgetful and might lose the remote
Something like this Phanteks Digital Controller Hub would probably work; it has a wired remote so it isn't something you can loose and it's fairly cheap (under your budget at the very least). It can also be connected a digital header on the MB (which your current board doesn't have otherwise you wouldn't need this adapter at all), which should work with any MB you get in the future.
