What fan speed should my GPU be on
xReqt
Using MSI Afterburner what fan speed should I put my RTX 2070 on? Its 50+ idle with a browser open. Bare in mind its 20% and not RPM
Quick response is appreciated.
PC SPECS
I7-8700 (non K)
GTX 1070
Corsair H100x AIO
16GB DDR4 Crucial ram (2133mhz)
Prime Z370-A Motherboard
Gamemax Falcon (White)
Peripherals
Logitech G305
Corsair Strafe MX RED
Blue Yeti /w arm
JVC (Headphones)
@xReqt
50c at idle ?! What is your room temp like?
mine runs idle around 29-32c and under normal
browsing like 35c
i have the fan curve set to auto. Fans don’t spin up until about 60c
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
@Stormseeker9 Everything else its below 45c should I put it to 40% and leave it
PC SPECS
I7-8700 (non K)
GTX 1070
Corsair H100x AIO
Peripherals
Logitech G305
Blue Yeti /w arm
JVC (Headphones)
Stock curve as fine so long as the GPU isn't throttling under a stress test
Brands I wholeheartedly reccomend (though do have flawed products): Apple, Razer, Corsair, Asus, Gigabyte, bequiet!, Noctua, Fractal, GSkill (RAM only)
Wall Of Fame (Informative people/People I like): @Glenwing @DrMacintosh @Schnoz @TempestCatto @LogicalDrm @Dan Castellaneta
Useful threads:
How To Make Your Own Cloud Storage
Guide to Display Cables/Adapters
PSU Tier List (Latest)-
Main PC: See spoiler tag
Laptop: 2020 iPad Pro 12.9" with Magic Keyboard
PCPartPicker Part List: https://pcpartpicker.com/list/gKh8zN
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core OEM/Tray Processor  (Purchased For $419.99)
Motherboard: Asus ROG Crosshair VIII Formula ATX AM4 Motherboard  (Purchased For $356.99)
Memory: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3000 Memory  (Purchased For $130.00)
Storage: Kingston Predator 240 GB M.2-2280 NVME Solid State Drive  (Purchased For $40.00)
Storage: Crucial MX300 1.05 TB 2.5" Solid State Drive  (Purchased For $100.00)
Storage: Western Digital Red 8 TB 3.5" 5400RPM Internal Hard Drive  (Purchased For $180.00)
Video Card: Gigabyte GeForce RTX 2070 8 GB WINDFORCE Video Card  (Purchased For $370.00)
Case: Fractal Design Define R6 USB-C ATX Mid Tower Case  (Purchased For $100.00)
Power Supply: Corsair RMi 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For $120.00)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  (Purchased For $75.00)
Total: $1891.98
Generated by PCPartPicker 2020-04-02 19:59 EDT-0400
身のなわたしはる果てぞ  悲しわたしはかりけるわたしは
50c at idle? Is that blower style cooler?
Main system: Ryzen 7 7800X3D / Asus ROG Strix B650E / G.Skill Trident Z5 NEO 32GB 6000Mhz / Powercolor RX 7900 XTX Red Devil/ EVGA 750W GQ / NZXT H5 Flow
I dunno whats happening i'm not PC savy so this is new to me @PopsicleHustler @SenpaiKaplan @Stormseeker9
PC SPECS
I7-8700 (non K)
GTX 1070
Corsair H100x AIO
Peripherals
Logitech G305
Blue Yeti /w arm
JVC (Headphones)
Download MSI Afterburner, and MSI Kombuster. Install both, and run Kombuster while looking at Afterburner. What temp does your GPU max out at?
Useful threads:
Total: $1891.98
What exact model of the 2070 do you have?
@Stormseeker9 MSI Armor 8G non OC
PC SPECS
I7-8700 (non K)
GTX 1070
Corsair H100x AIO
Peripherals
Logitech G305
Blue Yeti /w arm
JVC (Headphones)
Weird that your temps are that high. I have the same model. How is the airflow in your case? Any case fans? What case?
That explains it. MSI Armor cards are known for constant overheating problems thanks to a crap cooler.
What case cooling do you have?
@PopsicleHustler @Stormseeker9 Gamemax falcon 2uphere fans and 1 default with an AIO cooler
PC SPECS
I7-8700 (non K)
GTX 1070
Corsair H100x AIO
Peripherals
Logitech G305
Blue Yeti /w arm
JVC (Headphones)
Which they fixed on their 20xx series. Few people I know have 2070’s and non have heating issues. Maybe a faulty card perhaps?
@Stormseeker9 If I put it on 50% and leave it would there be any issues if not then when I do that I get 40% idle and 60-65 gaming 2 settings ultra rest mid-high
PC SPECS
I7-8700 (non K)
GTX 1070
Corsair H100x AIO
Peripherals
Logitech G305
Blue Yeti /w arm
JVC (Headphones)
Those temps are fine for under load. Similar to mine depending on the game and ambient temps of room.
@Stormseeker9 Again do you think if I put my fans on 50% it'll be fine?
PC SPECS
I7-8700 (non K)
GTX 1070
Corsair H100x AIO
Peripherals
Logitech G305
Blue Yeti /w arm
JVC (Headphones)
@Stormseeker9 with it on 50% idle temps go to 35-40 and 60-65% ingame thats pretty decent
PC SPECS
I7-8700 (non K)
GTX 1070
Corsair H100x AIO
Peripherals
Logitech G305
Blue Yeti /w arm
JVC (Headphones)
@Stormseeker9 Srry for so many questions I just need to know if its ok to keep it at 50% always :)
PC SPECS
I7-8700 (non K)
GTX 1070
Corsair H100x AIO
Peripherals
Logitech G305
Blue Yeti /w arm
JVC (Headphones)
Should be fine having them at 50%. If the noise doesn’t bother you, go ahead. Don’t think that in a normal lifespan of such a component it will wear out the fans extra fast before we replace the GPU.
@Stormseeker9 So it would reduce life span of anything :)
PC SPECS
I7-8700 (non K)
GTX 1070
Corsair H100x AIO
Peripherals
Logitech G305
Blue Yeti /w arm
JVC (Headphones)
The only part that gets stressed more is the fans themselves. Wont reduce the lifespan of the card itself.
