System power draw under load (Prime95+ Blend and FurMark 1080p)
191x7
I did the measurement last night. My system (with the two monitors) draws nearly 420W from the wall socket under Prime95+Furmark. Max at boot 200W.
Nearly the same system, just with an FX 8300 clocked at 4.4GHz drew about 550W. Boot power draw was at a max of 270W.
Can you do the same measurement?
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 30+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - HyperX Alloy Origins Core (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Arcadyan ISP router - 35/5 Mbps vDSL
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
What did you measure with? What monitors and graphics card are you using?
Primary PC:
4 minutes ago, Mira Yurizaki said:
What's the rest of the system?
I'm pretty sure if a FX-83XX dissipated 550W, you'd have a nuclear meltdown.
Thats whole system i think. FX chips can get quite hot. TR-levels, not quite skylake-X though (600W+ on direct die water)
A wattmeter that I plug into the wall socket and connect my power strip to it. Was some $20 in a store, I have it for a few years.
1 hour ago, Firewrath9 said:
200W idle? I get ~60
No, not IDLE. Peak at boot or should I say during boot.
Everything is mentioned in my profile.
And it wasn't heat dissipation but total system power draw.
The whole system, yes, but not TDP or heat dissipation but the power draw of the whole system from the 220V wall outlet.
3 minutes ago, Mira Yurizaki said:
Your profile is showing a Ryzen system.
And it is a ryzen system, the profile is accurate to the letter. Why?
I'm confused. You're saying you clocked an FX-8300, a Socket FM3+ CPU, but you're saying the system specs match what's in your profile, which is a Socket AM4 system.
Unless you're saying everything but the CPU, motherboard, and RAM are the same.
It might be your language barrier reading English. Try reading it again.
With the FX nearly everything was the same. True, the motherboard probably used 5W less than this one, but the ddr3 RAM used a tiny bit more than this DDR4.
The total power draw of the board&ram did not change significantly when upgrading, the CPU upgrade makes the most difference.
Ok, so what you want us to do, is to take out our FX systems, and compare wattages?
Nope, not FX, any system will do. This could help people stop recommending 1000W PSU-s for system that don't draw even 500W etc.
Its been concluded several times b4 that builds only take 400-550W, look at reviews.
