Recommendations for monitor stand for Samsung CHG70 32"
Solved by SuperCloneRanger,
That would work, its also AU$220.
I did some looking around and i think i found a solution for you so you can mount both monitors.
this 2 arm mount
https://www.amazon.com.au/Monitor-Adjustable-Grommet-Computer-Screens/dp/B07CWQ5S1Q/
With this vesa adapter for the non vesa monitor
https://www.amazon.com.au/Mount-Plus-MP-XMA-01A-Monitor-Non-VESA/dp/B074CTHBDJ/
reviews are't the best, but it should work if you use a better wrench than the one in the box
