CPU: i7-8700K
GPU: Asus dual-GTX1060-O6G
RAM: Corsair Vengeance LPX Black 16G
Mother Board: Asus ROG STRIXZ370-F gaming
SSD: Adata ASU800SS-128GT-C
Hard Drive: Seagate BarraCuda 1TB
Power Supply: EVGA 600 W1, 80+ WHITE 600W
+ Corsair Hydro H60 Liquid cooler
PC Case: Corsair Carbide SPEC-04
Guys are all of these parts compatible?? If YES... is it good?? Am I good to go and buy all of these parts ?
(PS: first time PC builder here but I’ve done some researching etc...)
I wanted my first build PC to be a Middle to Highendish~one.
https://linustechtips.com/topic/999687-need-help/
hey zeda099 all of the parts that you have listed are compatible and will work amazing at gaming
and yes it is good
right now the intel i7 8700k is one of the best cpus for gaming so will give you an fps increase over something like a ryzen 5 2600x
I use the asus dual  gtx 1060 6gb in my build and it help up well with an overclock of 150 on the core clock and 700 on memory but all cards are slightly different
the motherboard is a great choice and is perfect for overclocking I use the z370-e version and can clock my 8600k to 5ghz with ease
hope this helped
Arctic frost
my first build
cpu: intel i5 8600k
cpu cooler: ARCTIC - Freezer 33 eSports ONE
motherboard: Asus ROG strix z370-E
ram: Corsair - Vengeance LPX 16GB (4 x 4GB) DDR4-2133
ssd: Kingston - A400 240GB 2.5" Solid State Drive
hdd: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
gpu: Asus - GeForce GTX 1060 6GB Dual Series
case: NZXT - S340 Elite (White)
psu: EVGA - B3 550W 80+ Bronze
thanks to @seoz for helping make the list :P and its based of her custom rig
https://linustechtips.com/topic/999687-need-help/#findComment-12003630
