ram help
Go to solution Solved by nick name,
7 minutes ago, atg117 said:
does ram manufacture mean anything (hynix,micron,samsung) when building a amd pc and i am not going to oc the ram?
Only when it's Samsung b-die.  It's the best for AMD or Intel and can provide the best speeds and timings.  Kits with CL 16-18-18 are usually Hynix or something else and kits with matching CL like 14-14-14 , 15-15-15 , or 16-16-16 are usually Samsung b-die.  If you find something with matching CL then compare it against the Samsung b-die finder:
https://benzhaomin.github.io/bdiefinder/
Ryzen 2000 CPUs are much easier to run now with less expensive RAM kits like Hynix.  I had no problems with a 3200 16-18-18 Hynix kit, but I ugraded to a 3600 15-15-15 Samsung b-die for competitive benchmarking.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
https://linustechtips.com/topic/999303-ram-help/#findComment-12000905
so i can run hynix without a problem just in tearms for price i have got about 130 for ram sticks and it has to be compatible with the asus strix b350-f and it is very difficult to find 3000mhz ram
https://linustechtips.com/topic/999303-ram-help/#findComment-12001175
1 hour ago, jonrosalia said:
RYZEN or older AMD?
also what's the budget?
also the ram i have looked at is on the qvl but after the part number it has in brackets ver(4.24) so i wanted to know if i have to pay attention to what manufacture the ram chips are for compatibility reasons
https://linustechtips.com/topic/999303-ram-help/#findComment-12001201
$130 US dollars?  Are you in the US?
https://linustechtips.com/topic/999303-ram-help/#findComment-12001206
1 minute ago, atg117 said:
130 to 150
You can't find a 3200 kit for 130-150 pounds?
https://linustechtips.com/topic/999303-ram-help/#findComment-12001222
how low can the cl go?
At the price point your are shopping in you won't find better than 16-18-18 on a 3200 kit.  And the QVL list isn't gospel.  You will find kits not on it that will work fine with your setup.
https://linustechtips.com/topic/999303-ram-help/#findComment-12001248
aw ok thanks for the info dont want to get it wrong need ram or it wont even boot, i guess i can ask for someone when i find a kit i like. and for amd ryzen what is better duel channel or quad channel?
https://linustechtips.com/topic/999303-ram-help/#findComment-12001260
Quad channel is Threadripper.
https://linustechtips.com/topic/999303-ram-help/#findComment-12001265
