Hey guys, I need some help and advice on my first ever gaming setup. This is what I have down so far:
https://ca.pcpartpicker.com/list/Myt6jy
I will be using this PC for mostly gaming and personal use, and my budget is 2500 CAD including monitor, mouse, and keyboard. I think I also would might need a little bit more storage.
Can you guys give some suggestions? I'm still very new to PC building.
https://linustechtips.com/topic/999242-first-time-pc-builder-please-help/
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
2 minutes ago, paddy-stone said:
No, I haven't bought anything yet. This is my first ever PC build so I will need everything.
Ahh I see, OK let me make a few more changes then to try and maximize your build for your budget.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
Hmm, having a hard time getting that budget right.... especially for 1440p high refresh rate. This is what I have so far
I thought ryzen might be a more affordable option and dropping to a 1070ti, but the budget is still too tight IMO, plus peripherals will easily add another $200 for decent ones.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
Ok ty! So was my previous original build decent for a first timer? XD
It didn't have prices for some parts... so that's why it came in budget, lol
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
No price for mobo, ssd or case... so easily another $600-$1000 there.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
Will you be OCing the PC? if not I can drop a fair amount of the budget off there for intel build.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
Sorry, I didn't see your response, I don't really plan on OC'ing at the moment, but I probably will in the future.
There's only so much you can do with the expensive parts you wanted. I got as close as I could and even then the budget went kaput. I think you should consider a Ryzen build, either that or increase the budget a LOT or drop the expensive parts to a more reasonable level, for example you have a $500 1440p monitor, you can get a high refresh 144Hz 1080p monitor for around $200-ish IIRC. A 1070ti would be almost half the price you want to pay for the 2080, and so on.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
Ahh I just realised why certain parts weren't displaying, you had it set to display certain merchants only.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
OK final draft
By dropping the 2080 for a 1070ti, you could now have almost $400 to spend on peripherals, or get the better monitor or whatever. I would suggest just having 1TB SSD and a 3TB HDD, some games don't seem to improve loading times on SSD anyway, so my advice would be to load them on the SSD, and swap around between your HDD when you need to. It could get very expensive trying to have everything on SSD. Anyway, hope that helps :)
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
1 minute ago, paddy-stone said:
OK final draft
Thank you! I'll be sure to check it out.
CPU: Intel - Core i7-8700K 3.7 GHz 6-Core Processor  ($474.99 @ Newegg Canada)
CPU Cooler: RAIJINTEK - TISIS 70.2 CFM Sleeve Bearing CPU Cooler  ($59.49 @ Newegg Canada Marketplace)
Motherboard: MSI - MPG Z390 GAMING EDGE AC ATX LGA1151 Motherboard  ($204.00 @ Canada Computers)
Memory: Team - Vulcan 16 GB (2 x 8 GB) DDR4-3000 Memory  ($139.99 @ Newegg Canada)
Storage: Crucial - MX500 250 GB 2.5" Solid State Drive  ($57.59 @ Amazon Canada)
Storage: Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive  ($69.75 @ Vuugo)
Video Card: Gigabyte - GeForce RTX 2070 8 GB WINDFORCE Video Card  ($679.99 @ Memory Express)
Case: Corsair - Carbide Series 275R (Black w/Tempered Glass) ATX Mid Tower Case  ($84.99 @ Amazon Canada)
Power Supply: Rosewill - Capstone 750 W 80+ Gold Certified Semi-Modular ATX Power Supply  ($89.99 @ Newegg Canada)
Monitor: Dell - S2417DG 23.8" 2560x1440 165 Hz Monitor  ($499.99 @ Amazon Canada)
Keyboard: Corsair - K68 Wired Gaming Keyboard  ($89.99 @ Amazon Canada)
Mouse: Logitech - G502 Proteus Spectrum Wired Optical Mouse  ($49.00 @ Amazon Canada)
Total: $2499.76
Generated by PCPartPicker 2018-11-24 23:15 EST-0500
Total: $2499.76
Thank you!
Total: $2499.76
Yep, this ^ is a better list for sure.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
