I have a Sapphire Nitro + Vega 64, and there is quite a lot of coil whine, it is very noticeable to me when not wearing earphones or headphone. I normally do wear them, but being forced to wear them is annoying. Should I RMA the card.
Also I feel like it's not performing as well as it should, I am only getting about 70 fps in GTA V at Very high/high settings, I feel like I should be getting better performance than this. It is running on a 1080p ultrawide. I thought this was a card that could do 4k, if it can barely push 80fps at 1080p ultrawide how can it do 4k?
Specs:
  • i5-8600K
  • Evga Black RTX 2070
  • 16GB DDR4 2400MHz
  • ASRock Extreme 4 Z370
  • Fractal Design Meshify C Light TG
Plays: Minesweeper at 1000 fps.
https://linustechtips.com/topic/999141-vega-64-problems/
gta 5 is limited by network traffic and server speed so i'm not sure why you're using it as a benchmark
coil whine isn;t typically a problem people rma a card for but if you want to you can try. keep in mind the replacement will most likely do the same thing
https://linustechtips.com/topic/999141-vega-64-problems/#findComment-11999859
What do you mean server speed? I am playing single player Also I'm not using it as a benchmark, I am just saying it doesn't run that well.
Specs:
  • i5-8600K
  • 16GB DDR4 2400MHz
https://linustechtips.com/topic/999141-vega-64-problems/#findComment-11999882
i assumed you were playing the steam version
more than likely you have simply set every graphical setting to very high without optimizing it so if that's the case then yes leaving things like the AA running despite being at a res that doesn't need AA will yield poor fps
https://linustechtips.com/topic/999141-vega-64-problems/#findComment-11999906
I am but I'm not playing online
I set the graphics to a combination of high and very high, msaa is at 2x which is needed due to the low resolution.
Specs:
  • i5-8600K
  • 16GB DDR4 2400MHz
https://linustechtips.com/topic/999141-vega-64-problems/#findComment-11999973
well turn some things down then until you get the fps you want
sacrifice setting that do very little to the actual visuals and only impact performance , like the AA
https://linustechtips.com/topic/999141-vega-64-problems/#findComment-11999980
I'm not too worried about it at the moment, as I only have a 75Hz monitor, but I will soon have a 1920 by 1080 144Hz monitor. Am I correct to assume that as 2560 by 1080 is about a third more width that means I will get about a third more fps at 1920 by 1080? So if I get 75hz on ultrawide I would get 100 not on ultrawide? (or there about, I know it won't exactly work like that)
Specs:
  • i5-8600K
  • 16GB DDR4 2400MHz
https://linustechtips.com/topic/999141-vega-64-problems/#findComment-11999986
1 hour ago, emosun said:
Yeah you most likely will not see such a sheer linear performance scale that way.
Will it be more or less? If I get 75fps at 1080p ultrawide what am I likely to at 1080p 16:9?
Specs:
  • i5-8600K
  • 16GB DDR4 2400MHz
https://linustechtips.com/topic/999141-vega-64-problems/#findComment-12000226
7 minutes ago, emosun said:
why dont you set your monitor at that res and find out
I will try that. Another thing I don't understand re the differences in actual benchmarks. https://www.anandtech.com/show/11717/the-amd-radeon-rx-vega-64-and-56-review/14
and https://www.guru3d.com/articles-pages/asus-radeon-rog-rx-vega-64-strix-8gb-review,26.html
there is a massive difference of about 50fps in their results.
I tried changing the game resolution to 1080p and it made no difference to the fps, surely that cant be right.
Specs:
  • i5-8600K
  • 16GB DDR4 2400MHz
https://linustechtips.com/topic/999141-vega-64-problems/#findComment-12000236
4 minutes ago, emosun said:
more than likely their test machines are going to be configured better and contain faster parts.
without know what your configuration is and what and how you've added to the os its hard to see where you went wrong
I have an 8600K and 16GB of RAM, my computer was built three days ago so not much stuff downloaded. Surely configuring things slightly differently can't give the 50fps difference between those two sites.
Specs:
  • i5-8600K
  • 16GB DDR4 2400MHz
https://linustechtips.com/topic/999141-vega-64-problems/#findComment-12000278
Are your drivers up to date for the gpu ?Do you have both power plugs in the card ?Real world that card should run 80fps 1440p max settings in gta 5.So something is wrong with it like drivers or the card itself.Yes coil whine is normal ish but some companies will let you rma if its loud as you say.
https://linustechtips.com/topic/999141-vega-64-problems/#findComment-12000336
Both power connectors are in. I got the driver off of AMDs website two days ago. version 18.11.2
Specs:
  • i5-8600K
  • 16GB DDR4 2400MHz
https://linustechtips.com/topic/999141-vega-64-problems/#findComment-12000340
Just now, andrewmp6 said:
See if you can rma it over coil whine is what i would do.
Do you think there is a problem with the card and that is why I am getting rubbish performance?
Specs:
  • i5-8600K
  • 16GB DDR4 2400MHz
https://linustechtips.com/topic/999141-vega-64-problems/#findComment-12000346
I'm not sure whats wrong it with it yet.But how many watts is your psu ?Does the card only run like crap on gta 5 or is it like this for all games ?
https://linustechtips.com/topic/999141-vega-64-problems/#findComment-12002675
~80 FPS on GTA V is about correct.
It's a poorly optimized game, and favors nVidia GPUs more.
It's a console port game, and the developers did a really Janky job a bringing it over to PC.
Even the GTX 1080 Ti struggles to maintain ~50 FPS on 4K on Ultra quality.
This is with a
  • i7-7820X running at 4.3 GHz
  • Gigabyte X299 Aorus Gaming 7 motherboard
  • 32GB DDR4-3200 RAM
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/999141-vega-64-problems/#findComment-12002811
6 hours ago, andrewmp6 said:
After i watched a few review videos they are right your card is running best it can at gta 5,I knew the game didn't like amd cards but thought it would ran better then that at 1080p
https://www.youtube.com/watch?v=0aMAi2CrjnI
My CPU is maxing out as well as my GPU, is this right?
Specs:
  • i5-8600K
  • 16GB DDR4 2400MHz
https://linustechtips.com/topic/999141-vega-64-problems/#findComment-12003574
