first build :)
Go to solution Solved by GoldenLag,
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor  (€169.99 @ Amazon France)
CPU Cooler: be quiet! - Dark Rock 4 CPU Cooler  (€66.16 @ Amazon France)
Motherboard: MSI - X470 GAMING PRO CARBON ATX AM4 Motherboard  (€184.99 @ Cdiscount)
Memory: G.Skill - Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200 Memory  (€140.10 @ Amazon France)
Storage: Crucial - MX500 250 GB 2.5" Solid State Drive  (€42.90 @ Amazon France)
Storage: Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive  (€67.90 @ Cdiscount)
Video Card: Palit - GeForce RTX 2080 8 GB GamingPro OC Video Card  (€810.99 @ Amazon France)
Case: Cooler Master - MasterBox Lite 5 ATX Mid Tower Case  (€49.95 @ Cdiscount)
Power Supply: SeaSonic - FOCUS Plus Gold 750 W 80+ Gold Certified Fully-Modular ATX Power Supply  (€104.95 @ Amazon France)
Total: €1637.93
Generated by PCPartPicker 2018-11-23 11:58 CET+0100
throwing in a suggestion. dont know you budget, but im going to assume its around 1800euroes based on what you picked in the OP
hi,
i 'm try to select my first pc i ' m read some topic, is this good ?
RYZEN7 2700 EUR 278,91
MSI X470 EUR 151,94
MSI GEFORCE RTX 2080 Aero 8G EUR 942,86
Cooler Master MasterBox MB600L EUR 51,36
Western Digital WD30EZRZ 3to EUR 84,99
G.SKILL 16GB (2 x 8GB) EUR 140,89
Western Digital (WD) Green 240 Go M.2 2280 45€90
EVGA 600 W1, 80+ WHITE 600W EUR 44,99
i live in france and i use 4k tv for screen
i will use to play
thank's
https://linustechtips.com/topic/998654-first-build/
Total: €1637.93
https://linustechtips.com/topic/998654-first-build/#findComment-11996417
3 minutes ago, rdcdt said:
ok thank you
anything else ? :)
i would get a r5 2600 instead as you are playing at 4k, which means it will be a better option.
get a dark rock 4 from bequiet.
just take a look at the build i posted above
https://linustechtips.com/topic/998654-first-build/#findComment-11996427
thank you a lot
i forget to say i will use it also with a vive pro
https://linustechtips.com/topic/998654-first-build/#findComment-11996650
