I built my current system in 2012 and really don't have the money to start a new machine... but because of a recent move I need to recoup as much floor/desk space as humanly possible. My current case is a CoolerMaster HAF XB and although I thought it was an awesome form factor when I bought it, I see it as an awful waste of space now. Here are the relevant specs of my current rig:
  • Coolermaster HAF XB case
  • EVGA Nvidia GeForce GTX 970 4GB SC (242mm long)
  • Intel i5 3570k 3.4Ghz Socket  LGA 1155
  • Gigabyte Z77X-UP4
  • Hyper 212 Evo cooler (160mm tall)
  • Seasonic 750W PSU X750 Gold 170 mm (W) x 150 mm (L) x 86 mm (H)
I did some research on what the smallest cases were that would accommodate most of my existing parts and found the Phanteks Evolv Shift X to be very appealing. It looks like it has the footprint of an ionic breeze and still has room for my huge amount of drives and a full size graphics card.
The only two parts I would need to replace are my motherboard and my CPU cooler - I thought this would be a simple and economical decision since my socket type is so outdated now but boy was I wrong. I'm struggling to find find a new LGA1155 Mini ITX board for less than $220. I don't know how comfortable I feel with buying a refurb off eBay either. I had no idea what a premium these ITX boards were fetching.
Does anyone here have any advice on what motherboard to look for? Ideally I want one less than $150, bonus points for under $100. Is this a pipe dream? Should I try to go for mATX instead? I'm really in love with this case.
https://linustechtips.com/topic/998315-need-help-downsizing-my-current-rig/
What about a very small midtower out of the fractal design node series? Would be way more economical than getting a new mobo for such an old platform. I know it ain't pretty, but certainly works
Edit: I'm a bit outdated on the lineup they have, sth like the focus g seems small as well. Point stays the same; don't invest tons of money in such a old system
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
Buying new for old parts will always be a headache. The solution truly is to buy used, and it's not as bad as it's made out to be.
Primary PC:
PSU tier list
How many watts do I need?
It's reassuring to hear that. Are there any boards for my socket type that you would particularly reccomend as a good value used?
200mm width is not a small enough footprint for my situation which is why I decided to go with a different form factor altogether. None of the mid towers I found were small enough to appeal to me.
So I found this one
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F123505969561
Which includes a CPU which you could probably sell back (or maybe keep as backup), but I'm not sure if you're in need of an overclocking board or not. If you don't require a Z series board, the options get even cheaper, so an H77 board has more value.
Primary PC:
PSU tier list
5 minutes ago, fasauceome said:
So I found this one
Unfortunately the description says it doesn't come with the IO backplate... wouldn't that be a risk?
That's a cosmetic item more than anything, but it makes sense if you don't want to buy a motherboard without the I/O shield
Primary PC:
PSU tier list
As long as there's no electrostatic risk I suppose I'm not concerned. If I'm not overclocking would I be okay switching back to the stock cooler or do I need to find a shorter aftermarket one that would fit in the Phasetek case? It has an 82mm clearance.
Intel stock is no good, there are better coolers like the noctua NH-L9i or the Silverstone AR06. Also, step down to an H77 board to save money.
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F183537737912
Primary PC:
PSU tier list
The HAF XB has the motherboard configured horizontally, so it would some space.
Have you considered moving your parts into a more conventional upright computer case?
Would that work better?
Say...Phanteks P350X?
http://www.phanteks.com/Eclipse-P350X.html
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
I decided to go with the Zotac ZT-H77ITX-A-E. After reading up on the chipset differences I had no issues downgrading from Z77 to H77. The extra $$ is not worth the overclock capability. I don't even think I ever utilized it on my current board. I'll order the Noctua cooler soon too. Thank you for your help, it was greatly appreciated!
