Yes it's normal,
you really don't want to tighten all the way, it will cut the tube
Cpu: Intel i7 4770k @4.4 Ghz | Case: Corsair 350D | Motherbord: Z87 Gryphon | Ram: dominator platinum 4X4 1866 | Video Card: SLI GTX 980 Ti | Power Supply: Seasonic 1000 platinum | Monitor: ACER XB270HU | Keyboard: RK-9100 | Mouse: R.A.T. 7 | Headset : HD 8 DJ | Watercooled
https://linustechtips.com/topic/99818-compression-fittings-help/#findComment-1335442
my compression fittings wont tighten all the way. is this normal?
could you elaborate on that a bit more? pix would be better..
the fittings will not tighten anymore because? no more thread?, o-ring seal is squeezing out?
https://linustechtips.com/topic/99818-compression-fittings-help/#findComment-1335502
no when i put the tube on then screw it down
if you are reading this you are wasting valuable time and should maybe rethink your life choices.
https://linustechtips.com/topic/99818-compression-fittings-help/#findComment-1335513
is your tubing diameter quite thick? Sometimes it wont screw all the way down due to that. I know the Primochill tubing has very thick walls and wont. then i moved to mustklear and i could easily screw them all the way down. If you are worrying about it put some toilet paper around them when testing for leaks.
Quack 🦆
https://linustechtips.com/topic/99818-compression-fittings-help/#findComment-1335521
remember, there will be little to no pressure in the system .and you are only wanting the
locking ring (outside ring) to cinch the tube for a seal. not looking for decapitation. and as
a rule on comps, several heat cycles and your going to retighten the fittings again. and again..
https://linustechtips.com/topic/99818-compression-fittings-help/#findComment-1335593
