So, I need more pci slot spaces. Dual gpu and my aio block nearly all of them, and putting cards in the free ones equals rip fans and gpu cooling. I'm going to 3d print myself a bay to go in my CD bays, four pci slots in 2 bays using one of the pci slot extenders off eBay. However, they all use usb over a small pci card. Is this pci card neccarsary? Can't I just slap it straight into one of my free usb 3.0 headers with an adapter?
Pci cards for the win
And also, if anyone knows where to get pci to floppy connector or even sata or idea to floppy I'll be eternally grateful.
Thanks
https://linustechtips.com/topic/997971-pci-through-usb/
To be clear, do you need more PCI expansion slots or PCIe expansion slots?
If PCI, then get something similar to this:
https://www.aliexpress.com/item/PCIe-To-PCI-Dual-Slot-Adapter-Card-PCI-Express/558769291.html
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/997971-pci-through-usb/#findComment-11991423
you are talking about a PCI-E riser card, people used them a lot for mining rigs. They are not converting anything to USB, they just use USB 3.x connectors and wires to send the PCI-E signals between the small 1x slot adapter and the main add-on circuit board (usually with a 16x size slot on it); so no, you can't plug those into USB ports, the signals are not at all USB spec.
HEDT: i9 10980XE @ 4.9 gHz, 64GB @ 3600mHz CL14 G.Skill Trident-Z DDR4, 2x Nvidia Titan RTX NVLink SLI, Corsair AX1600i, Samsung 960 Pro 2TB OS/apps, Samsung 850 EVO 4TB media, LG 38GL950G-B monitor, Drop CTRL keyboard, Decus Respec mouse
Laptop: Razer Blade Pro 2019 9750H model, 32GB @ 3200mHz CL18 G.Skill Ripjaws DDR4, 2x Samsung 960 Pro 1TB RAID0, repasted with Thermal Grizzly Kryonaut
Gaming Rig: i9 9900ks @ 5.2ghz, 32GB @ 4000mHz CL17 G.Skill Trident-Z DDR4, EVGA RTX 2080 Ti Kingpin, Corsair HX1200, Samsung 970 EVO Plus 2TB, Asus PG348Q monitor, Corsair K70 LUX RGB keyboard, Corsair Ironclaw mouse
HTPC: i7 7700 (delidded + LM), 16GB @ 2666mHz CL15 Corsair Vengeance LPX DDR4, MSI Geforce GTX 1070 Gaming X, Corsair SFX 600, Samsung 850 Pro 512gb, Samsung Q55R TV, Filco Majestouch Convertible 2 TKL keyboard, Logitech G403 wireless mouse
https://linustechtips.com/topic/997971-pci-through-usb/#findComment-11994427
