Weird CPU problem after upgrades.
Solved by MeltyMoon,
I'm running World of Warcraft right now with temps of 75-89 degrees. Using RealTemp
Yea that's definitely an issue. This is on stock right? Do you have any spare thermal paste lying around? I would suggest taking the stock cooler off, cleaning off all of the TIM and reapplying some new thermal material. I would believe that your temps are causing the CPU to throttle in an attempt to keep it's temperature down, which is causing your performance hits in games.
