I've been sick to my stomach all day wondering how I should go about cooling in this build.
Questions:
1. Should I buy more fans
2. Should I buy an RGB air cooler for AESTHETICS
3. Should I buy a better performance cooler
4. Should I buy the H7-Quad Lumi and change the white lit fan?
5. Buy AIO and die of leaks?
I've mind blanked! Comment your thoughts and suggestions!
https://linustechtips.com/topic/997551-cooling-argh-help/
You could just get a aio cooler but besides that it looks like it has enough cooling even for minor overclocking
CPU:R9 3900x@4.5Ghz RAM:Vengeance Pro LPX @ 3200mhz MOBO:MSI Tomohawk B350 GPU:PNY GTX 1080 XLR8
DRIVES:500GB Samsung 970 Pro + Patriot Blast 480GB x2 + 12tb RAID10 NAS
MONITORS:Pixio PX329 32inch 1440p 165hz, LG 34UM68-p 1080p 75hz
https://linustechtips.com/topic/997551-cooling-argh-help/#findComment-11987912
If you're buying an 8700 then I'd imagine you'd be fine with your current selection.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
https://linustechtips.com/topic/997551-cooling-argh-help/#findComment-11987919
And are those prices in Australian Koala Dollars?
https://linustechtips.com/topic/997551-cooling-argh-help/#findComment-11987923
CPU cooler's good enough, extra case fans are a good idea
Desktop benching:
https://linustechtips.com/topic/997551-cooling-argh-help/#findComment-11987924
10 minutes ago, BiBiAhn said:
Scared of leaks my dude
It's near impossible for it to leak and even if it did the liquid inside is usually not conductive so it wouldn't damage anything. But. I have had aios for awhile and I've even held a motherboard by the radiator before with no issues they can take a beating. Maybe if you did a custom watercooled loop then leaks should be worrying but aios are completely self contained
https://linustechtips.com/topic/997551-cooling-argh-help/#findComment-11987940
AIOs do leak (it's happened to me before), but not often. It's mostly the pump that dies in an AIO first.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/997551-cooling-argh-help/#findComment-11988008
31 minutes ago, BiBiAhn said:
Should I get different fans (If so, what would you recommend?) or more of the same ones?
The stock fans (GP12) are alright, I'd keep on using them but not buy more of the same fans.
If colour is not an issue I'd put Noctua F series fans on places with air filters, A series on other places. If colour is a problem, then Fractal's own HP12/14 shall do
Desktop benching:
https://linustechtips.com/topic/997551-cooling-argh-help/#findComment-11988165
What you have is fine but you could save some money with a cheaper cooler like a M9i: https://au.pcpartpicker.com/product/LPVBD3/cryorig-cpu-cooler-m9i
or PR Slim if you want something quieter: https://au.pcpartpicker.com/product/hyQRsY/be-quiet-pure-rock-slim-351-cfm-cpu-cooler-bk008
If it's a matter of aesthetics, go with whichever looks good to you.
https://linustechtips.com/topic/997551-cooling-argh-help/#findComment-11992270
I currently have a H7 Plus and It's loud as fuck, and I'd rather go for aesthetics as well. Do you think AIO is a good idea? I move my pc frequently (LANS and house) and both have their cons when it comes to damage. I would love your input
https://linustechtips.com/topic/997551-cooling-argh-help/#findComment-12002362
What are your temps and what rpm are you running the cpu fans at? The 8700 is easy to cool and the H7 Plus shouldn't be very loud at all.
https://linustechtips.com/topic/997551-cooling-argh-help/#findComment-12004076
H7 is a good choice, cange the fan if its to noisy, if u want to go better cooling just grab the king, NH-D15, and be done.
Dont get a AIO...please.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
https://linustechtips.com/topic/997551-cooling-argh-help/#findComment-12004281
pretty solid build for something (dunna know why wasn't disclosed)
  1. depends on your comfort of the cooling once built
  2. if RGB is your thing, then spend the money
  3. more money for a small amount of thermal satisfaction
  4. see #2
  5. since you already have that mindset of leaks, then no.
https://linustechtips.com/topic/997551-cooling-argh-help/#findComment-12004415
