NEED NEW BUILD ADVICE
Go to solution Solved by Spotty,
1 minute ago, AnimeFantasyXV said:
So pretty much I want to be able to play every new game to come out
    For 2019 or the start of them. I'm looking to play at Max settings or High settings at 1080p or even 2160p
CPU
AMD Ryzen 7 1700
Motherboard
ASRock Taichi X370
RAM
Viper 8GB 2400MHZ
GPU
EVGA GTX 1060 6GB SSC
You should upgrade to 16GB of RAM, and preferably faster RAM since Ryzen works best with faster memory.
The GTX 1060 6GB will be fine for 1080p, but not for 4k in those titles.
7 minutes ago, AnimeFantasyXV said:
1. Cyber Punk 2077
2. Fallout 76
3. Fallout 4 Modded
4. Skyrim SE Modded
5. Grand Theft Auto 5 Modded
5. Forza Horizon 4
6. Final Fantasy XV
1. Not yet released, need more RAM
2. Probably full of bugs anyway, need more RAM
3. Depends on the mods, need more RAM
4. Depends on the mods, need more RAM
5(a). Depends on the mods, need more RAM
5(b). Need more RAM
6. Need more RAM
6 minutes ago, AnimeFantasyXV said:
Display(s)
VIZIO 32 inch D32hn-E4
Your monitors TVs resolution is only 720p, so if you're planning on playing 1080p or 4k you will need to buy a new monitor.
Hi there is my build any good? and if so what games could I play? and at what settings? or resolutions?
Here are some games I'm looking forward to
1. Cyber Punk 2077
2. Fallout 76
3. Fallout 4 Modded
4. Skyrim SE Modded
5. Forza Horizon 4
6. Final Fantasy XV
So pretty much I would like to be able to play every new game to come out For 2019 or at least the start of 2019.
If there are any upgrades that I should Invest in Please Let me know that would be really neat. Tank you
System
  • CPU
    AMD Ryzen 7 1700
  • Motherboard
    ASRock Taichi X370
  • RAM
    Viper 8GB 2400MHZ
  • GPU
  • Case
    NZXT H500 (WHITE)
  • Storage
    Sandisk 500GB SSD
  • PSU
    Thermaltake RGB 750W PSU
  • Display(s)
  • Cooling
    AMD Stock RGB Cooler
  • Keyboard
    Logitech - G513 Carbon RGB Wired Gaming Mechanical Romer-G Linear Switch Keyboard - Carbon
  • Mouse
    Original Razer RGB Death Adder
  • Operating System
    Windows 10 Pro
https://linustechtips.com/topic/996709-need-new-build-advice/
Where are you located, what's your budget?
CPU: Intel I5-7500
CPU Cooler: Cooler Master ML240
Motherboard: ASRock B250M PRO 4
Memory: 16GB Patriot Viper Elite
Gpu: Asus Dual 1060 3GB
Storage: Corsair 120GB M.2 NVME
500GB Samsung 860 EVO
1TB WD Blue
Power Supply: EVGA 500W 80+Bronze
Case: Phanteks P350X
Monitors: HP Omen 25in 144hz
and some 25in Acer
Keyboard: Corsair K70 LUX RGB
Mouse: Corsair M65 Pro
Headphones= VModa Crossfade Wireless(but used wired)
Speakers: Some janky speakers I jerry-rigged
https://linustechtips.com/topic/996709-need-new-build-advice/#findComment-11980930
if that's a single stick of memory, add another 8GB stick to it. Otherwise, add a pair of 4gb to it.
Desktop benching:
https://linustechtips.com/topic/996709-need-new-build-advice/#findComment-11980942
CPU
AMD Ryzen 7 1700
Motherboard
ASRock Taichi X370
RAM
Viper 8GB 2400MHZ
GPU
1. Cyber Punk 2077
2. Fallout 76
3. Fallout 4 Modded
4. Skyrim SE Modded
5. Forza Horizon 4
6. Final Fantasy XV
5(b). Need more RAM
6. Need more RAM
Display(s)
https://linustechtips.com/topic/996709-need-new-build-advice/#findComment-11980943
