Hey,
I might be building my parents a new system. The idea is to have a small, simple, quiet and reasonably cheap PC that's powerful enough to simply browse the web, play flash (youtube HD, flash games,...) and be used for some simple MS Office stuff. I'd like a computer that is still powerfull enough to play stuff like minecraft fluidly (for my little brother). The most important aspect is that it has to be snappy. They won't do any serious stuff with the PC, but waiting 30 secs for a browser to open isn't acceptable. There is no need for mass storage.
I've configured this with PC part picker, but I'm not sure if it'll be enough for the goals I'm setting. OS is Windows 7 Ultimate (already have a copy). Location is Belgium
PCPartPicker part list / Price breakdown by merchant / Benchmarks
CPU: AMD A4-3300 2.5GHz Dual-Core Processor ($39.97 @ OutletPC)
Motherboard: ASRock A75M-ITX Mini ITX FM1 Motherboard ($89.99 @ SuperBiiz)
Memory: A-Data Premier Series 4GB (1 x 4GB) DDR3-1333 Memory ($45.99 @ Amazon)
Storage: Kingston SSDNow V+200 90GB 2.5" Solid State Disk ($92.99 @ SuperBiiz)
Case: Fractal Design Node 304 Mini ITX Tower Case ($72.99 @ NCIX US)
Power Supply: SeaSonic 300W 80+ Bronze Certified ATX Power Supply ($39.99 @ Mwave)
Total: $381.92
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-01-08 15:44 EST-0500)
Please do share your thoughts.
https://linustechtips.com/topic/99641-simple-webbrowsing-system/
Seems good to me ^_^ especially with APUs and web browsers playing nicely with them this seems very good :P .
Console optimisations and how they will effect you | The difference between AMD cores and Intel cores | Memory Bus size and how it effects your VRAM usage |
How much vram do you actually need? | APUs and the future of processing | Projects: SO - here
Intel i7 5820l @ with Corsair H110 | 32GB DDR4 RAM @ 1600Mhz | XFX Radeon R9 290 @ 1.2Ghz | Corsair 600Q | Corsair TX650 | Probably too much corsair but meh should have had a Corsair SSD and RAM | 1.3TB HDD Space | Sennheiser HD598 | Beyerdynamic Custom One Pro | Blue Snowball
https://linustechtips.com/topic/99641-simple-webbrowsing-system/#findComment-1333038
Shameless self-bump after waiting 2 days. I still would like a semi-definitive answer to the noise levels of the stock AMD cooler.
I'm also unsure if the APU will perform well enough in general usage. (as in, it will be snappy)
Anyone care to chime in? I'm willing to offer cookies :)
https://linustechtips.com/topic/99641-simple-webbrowsing-system/#findComment-1346019
Shameless self-bump after waiting 2 days. I still would like a semi-definitive answer to the noise levels of the stock AMD cooler. I'm also unsure if the APU will perform well enough in general usage. (as in, it will be snappy) Anyone care to chime in? I'm willing to offer cookies :)
 the stock cooler is loud, but not really a deal breaker. i recommend this, its for cpus with a tdp of upto 95W so that 65W apu is gonna run whisper quiet on PWM. APUs are perfect for web browsing and watching hd videos. and it will be able to run the games, wont be the best but options slap on a hd 7770/7790 which are well cheap or even crossfire with a hd 6xxx and save more moneys. also remember with APUs, gaming is improved with faster ram.
https://linustechtips.com/topic/99641-simple-webbrowsing-system/#findComment-1346092
You might consider an Intel solution:
CPU:  Intel Core i3-4130 3.4GHz Dual-Core Processor  ($119.98 @ OutletPC)
Motherboard:  ASRock H81M-HDS Micro ATX LGA1150 Motherboard  ($49.99 @ Microcenter)
Memory:  G.Skill Ripjaws Series 4GB (2 x 2GB) DDR3-1600 Memory  ($43.92 @ NCIX US)
Storage:  Kingston SSDNow V300 Series 120GB 2.5" Solid State Disk  ($74.99 @ Amazon)
Case:  Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case  ($39.99 @ Microcenter)
Power Supply:  SeaSonic 350W 80+ Bronze Certified ATX Power Supply  ($39.99 @ Mwave)
Total: $368.86
(Generated by PCPartPicker 2014-01-11 01:56 EST-0500)
I also made up a build with parts available at fr.pcpartpicker. You'll notice there are some differences which should provide alternative options should part availability and pricing be very different where you are shopping.
CPU:  Intel Core i3-4130 3.4GHz Dual-Core Processor  (€105.45 @ Amazon France)
Motherboard:  ASRock B85M-HDS Micro ATX LGA1150 Motherboard  (€59.45 @ Amazon France)
Memory:  G.Skill 4GB (2 x 2GB) DDR3-1600 Memory  (€44.40 @ Amazon France)
Storage:  Kingston SSDNow V300 Series 120GB 2.5" Solid State Disk  (€71.23 @ Amazon France)
Case:  Cooler Master N200 MicroATX Mid Tower Case  (€44.70 @ Amazon France)
Power Supply:  Antec EarthWatts Green 380W 80+ Bronze Certified ATX Power Supply  (€49.65 @ Amazon France)
Total: €374.88
(Generated by PCPartPicker 2014-01-11 08:05 CET+0100)
https://linustechtips.com/topic/99641-simple-webbrowsing-system/#findComment-1346901
CPU: Intel Pentium G550 2.6GHz Dual-Core Processor ($49.98 @ SuperBiiz)
Motherboard: Gigabyte GA-H61M-S1 Micro ATX LGA1155 Motherboard ($37.48 @ Newegg)
Memory: Kingston 4GB (1 x 4GB) DDR3-1333 Memory ($35.70 @ NCIX US)
Video Card: XFX Radeon HD 6670 1GB Video Card ($60.38 @ Newegg)
Case: Silverstone SST-SG02B-F-USB3.0 (Black) MicroATX Desktop Case ($62.98 @ Newegg)
Total: $361.50
(Generated by PCPartPicker 2014-01-11 06:12 EST-0500)
https://linustechtips.com/topic/99641-simple-webbrowsing-system/#findComment-1347593
Hmmm, lots of Intel solutions. I immediately thought of AMD because of the price/performance ratio usually being better. Will I be better off buying Intel your opinion? If so, why?
Do you know this from experience? I'm quite reluctant on any fan that isn't from a well-known corporation. It may be rated for 95W, but so is the AMD stock cooler, as it comes with APUs up to 130W ;)
https://linustechtips.com/topic/99641-simple-webbrowsing-system/#findComment-1347719
Browsing modern web sites requires a decent cpu for a good experience. Waiting while a cpu sorts out all the objects on a page and downloads the various pieces is not the best of experiences. The two cores and hyperthreading of an i3 will provide a far better browsing experience than any two core cpu. Part of the reason Chrome is so fast is the number of parallel processes it uses.
https://linustechtips.com/topic/99641-simple-webbrowsing-system/#findComment-1349403
Do you know this from experience? I'm quite reluctant on any fan that isn't from a well-known corporation. It may be rated for 95W, but so is the AMD stock cooler, as it comes with APUs up to 130W ;)for
Yes, I wouldnt recommend it unless ive used it, the cooler is a pain to fit but youll only need to do it once. the heat sink in the amd stock is smaller and has a smaller fan, the fan needs  to spin faster under load so is noisier compared to the arctic cooling cooler which has a bigger heat sink and a bigger fan and rubber isolaters. anyway it also does depend on the case, how close you sit to the computer and how sensitive you are to the noises it could make.
https://linustechtips.com/topic/99641-simple-webbrowsing-system/#findComment-1350675
