RTX 2070 Power Limit
Go to solution Solved by Fasauceome,
1 hour ago, AkSo2504 said:
i know they have a strict power limit but when i put the power limit to 125% it doesnt matter and the actual power limit will be still below that?
It may not matter, the cards probably enforce a stricter power limit than software allows
The RTX cards have a really firm power limit, they are not overclock friendly.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/996407-rtx-2070-power-limit/#findComment-11978556
Primary PC:
PSU tier list
https://linustechtips.com/topic/996407-rtx-2070-power-limit/#findComment-11978862
