i had posted on the forums once before asking for help deciding on a desktop build and after i had finished , i got the news that i was nominated for a scholarship that will take me outside the country for an extended period , so i went back to square one on deciding on whether i should get a desktop for gaming and then get a laptop for when i leave , or if  i should get a gaming laptop , i am leaning more towards the later option since i want have to pay for 2 systems , so can anyone help me , and if u can suggest what is the best system i should get my budget is up  to 2500$ ,i read the guide but would like for further opinions since i am kinda of an indecisive person
https://linustechtips.com/topic/995999-help/
The real question is what tasks does that laptop need to do? I use a desktop and cheap laptop but my laptop doesn't do much work.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/995999-help/#findComment-11975258
other than gaming since i will be leaving the country for a year at least, mostly running analysis and simulation programs
https://linustechtips.com/topic/995999-help/#findComment-11975272
Since you need a laptop to do a beefy job on the go, I recommend a nice expensive one like a Dell XPS
Primary PC:
PSU tier list
https://linustechtips.com/topic/995999-help/#findComment-11975293
1 hour ago, SoftMist said:
the budget is 2500$ that is why i am looking for suggestions i was told that Asus or MSI can do a good job
The asus Zepyrus could also be good for your purposes.
Primary PC:
PSU tier list
https://linustechtips.com/topic/995999-help/#findComment-11975527
Is portability very important to you?
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/995999-help/#findComment-11977423
If you don't need gaming on the go (only game in dorm), you might want to consider desktop+laptop (regular/Ultrabook) or eGPU
Desktop specs:
https://linustechtips.com/topic/995999-help/#findComment-11984956
it seems like something is not clear so i will explain , if i buy a desktop it will stay here in Jerusalem while i move to Scotland , that is why i need a laptop
https://linustechtips.com/topic/995999-help/#findComment-11985870
I see.
May I know your usage? Any preference on weight and battery life? Any other special requirements? Any links of online stores?
Desktop specs:
https://linustechtips.com/topic/995999-help/#findComment-11989191
