Cpu: i5 4670k (stock speeds)
Mobo: Asrock H97m PRO4
Ram: Gskill 2x4gb 1600hz, and patriot 1x8gb 1600mhz
Gpu: Asus Strix 1060 6gb
Storage: HP M700 120gb ssd
Western Digital green 1tb hdd
PSU: Evga 500 B1
OS: Windows 10 Home 64bit
So i built my friend a computer not too long ago, and he says his computer has been frame dropping like crazy. He would try to reduce settings to increase fps, but even with lowering the settings, the fps stays low. His computer struggles in games like Maplestory 2, fortnite, black ops 4, overwatch etc...
I ran Unigine heaven at his house, so i dont have the snippet on me, but his avg fps was 52.9 fps on extreme.
I tried putting his computer in high performance mode, used ddu and reinstalled drivers, changed priorities in task manager, but nothing helped....
Anything helps! Thanks for reading
https://linustechtips.com/topic/995830-custom-built-pc-is-underperforming/
Take that 1 8GB stick of RAM out, then run Heaven and some games again and monitor CPU, RAM, and GPU usage (task manager is fine for CPU and RAM, but MSI Afterburner or HWMonitor is better, and more reliable for GPU usage). Also, I'm gonna need more quantifiable data than "low" and "underperforming". Another also, Unigine benchmarks change intensity based on resolution of the monitor (just like any game), so that's needed info too
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
