Hello!
In July i upgraded my PC and bought an NHD-15 air cooler. Which I regret now, since it's not really pretty to look at. So i've come to the conclusion that i wanna buy an AIO but, i am not sure if there is room in my case. What would be the max. size for an AIO? Can you recommend any for my CPU, might overclock :)
The specs:
Motherboard: ASUS ROG STRIX Z370-F GAMING
RAM: CMK16GX4M2B3000C15
CPU: i5-8600K
Graphics card: Asus strix 1070
Case: Fractal Design Meshify C
Thanks ❤️
https://linustechtips.com/topic/995536-clearence-for-aio/
1 hour ago, Benj1 said:
240 mm AIO if you want to top mount, 280 or 360 mm AIO if you don't mind front mounting. Anything bigger than a 280 mm AIO should outperform the NH-D15. Having said that the Meshify C has some length limitations so if you want to go stock, you should stick to the 240 mm AIO on the top.
Otherwise you have to get creative with your fan mounting in the front to clear the graphics card,
https://linustechtips.com/topic/995536-clearence-for-aio/#findComment-11971824
Yeah, Strix 1070 won't fit with the radiator in the front, so 240 at the top is the way to go I suppose. Just don't forget to get better fans, as most of stock fans leave a lot to be desired
Ex-EX build: Liquidfy C+... R.I.P.
Ex-build:
Meshify C – sold
Ryzen 5 1600x @4.0 GHz/1.4V – sold
Gigabyte X370 Aorus Gaming K7 – sold
Corsair Vengeance LPX 2x8 GB @3200 Mhz – sold
Alpenfoehn Brocken 3 Black Edition – it's somewhere
Sapphire Vega 56 Pulse – ded
Intel SSD 660p 1TB – sold
be Quiet! Straight Power 11 750w – sold
https://linustechtips.com/topic/995536-clearence-for-aio/#findComment-11971896
3 hours ago, Benj1 said:
Hello!
The specs:
CPU: i5-8600K
Thanks ❤️
with that GPU you won't be able to do a front mounted radiator unless you're open to some modding.
check my bio for one of the ways to fit a strix card in the meshify c.
option 2: if you really want a front mounted radiator you can mount the fans outside the frame and have to cut some bits of the front panel: Click here for video
other than that the top supports 240/280
with that said tho i would go with a 240 instead of a 280 since clearance is a issue with the motherboard.
Specs: Ryzen 9800X3D 5425MHz - ASUS TUF RTX 4080 super - G.Skill Trident Z5 Neo 64GB 6400MT/s CL26 -  Gigabyte X870 AORUS Elite Wifi7 ICE - Torrent Fractal Design white - EVGA 850W Supernova G2 80+ Gold - Noctua NH-U12A
https://linustechtips.com/topic/995536-clearence-for-aio/#findComment-11972234
Where in your bio is the other way? Can't seem to find it :)
https://linustechtips.com/topic/995536-clearence-for-aio/#findComment-11975308
i meant in my signature below, sorry
here's the link to it: Meshify C 1080ti ''strix''
https://linustechtips.com/topic/995536-clearence-for-aio/#findComment-11975369
Thanks for the link! Not sure if i'm up for the challenge tho :/
I think i'll go for a 240 mm AIO in the top then - but won't that have an impact on the temps?
I was thinking about getting an NZXT Kraken X52 to go with my hue+ AER fans and the strip. You think that would be good? :)
And btw, how long are your cables? I've been considering getting sleeved cables but weren't sure about the cables :)
https://linustechtips.com/topic/995536-clearence-for-aio/#findComment-11975918
i think you will see the same temps with a 240mm compared to the D15.
i went with 600mm cable length, this is too long for this case but since i like to swap cases i always go for longer ones just in case my next case is bigger and longer cables are needed.
with that said i think in this case 450mm should be fine.
edit: if you want to be 110% sure get a cable or a wire and go from the 24pin to the PSU and you will have the length you need :) (same for your other cables of course 8pin eps and the pcie ones.
https://linustechtips.com/topic/995536-clearence-for-aio/#findComment-11976352
Since you got a D15, i'd sugest atleast a 280mm AIO, or preferably a 360mm.
240mm , depending on the exact one you get will be ether 'as good' or worse than the D15, and will most certanly be louder at the fan speeds you will need to match the D15.
Honestly the D15 is the better cooler, but if all u care about is asthetics, then sure grab any 240mm AIO u like the look of.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
https://linustechtips.com/topic/995536-clearence-for-aio/#findComment-11976436
Thanks! :)
With the Bitwit mod there, would i be able to fit a 240-280mm rad?
https://linustechtips.com/topic/995536-clearence-for-aio/#findComment-11978256
