i want to upgrade my computer and need help to find the best parts for it, i have a 600€ budget
what i want to upgrade is = CPU, Motherboard and the Case
i was thinking about getting the ryzen 7 2700x but the rest idk what to get
the reason i want a new case is bc my old one has some broken ports and stuff like that.
what i currently have is=
Motherboard: Gigabyte B150-HD3P
CPU: i5-6500
CPU cooler: stock
GPU: gtx 1070
RAM: 2x8gb ddr4-2133
Case: some cheap case idk the name of rn
PSU: i think it was 530 watt
Storage: 1tb HDD and 240gb SSD
https://linustechtips.com/topic/995039-pc-upgrade-help/
https://linustechtips.com/topic/995039-pc-upgrade-help/#findComment-11967120
For the case, the NZXT H500 or Corsair 100r. Both are pretty cheap and have a decent amount of space.
The Ryzen 7 2700x is a good CPU. if you plan on going with that, nab pretty much ~$100 AM4 motherboard with either B350/450 or X370/470.
If you do not plan on overclocking, the stock wraith cooler will do you well enough. If you do plan on overclocking, or have some extra budget grab a decent aftermarket cooler such as the bequiet! dark rock pro
Edit: Make sure that the new hardware can be handled by your PSU, if not then get a new one with an upgraded power rating
Primary PC: - https://pcpartpicker.com/list/8G3tXv (Windows 10 Home)
HTPC: - https://pcpartpicker.com/list/KdBb4n (Windows 10 Home)
Server: Dell Precision T7500 - Dual Xeon X5660's, 44GB ECC DDR3, Dell Nvidia GTX 645 (Windows Server 2019 Standard)
*SLI Rig* - i7-920, MSI-X58 Platinum SLI, 12GB DDR3, Dual EVGA GTX 260 Core 216 in SLI - https://pcpartpicker.com/list/GHw6vW (Windows 7 Pro)
HP DC7900 - Core 2 Duo E8400, 4GB DDR2, Nvidia GeForce 8600 GT (Windows Vista)
Compaq Presario 5000 - Pentium 4 1.7Ghz, 1.7GB SDR, PowerColor Radeon 9600 Pro (Windows XP x86 Pro)
Compaq Presario 8772 - Pentium MMX 200Mhz, 48MB PC66, 6GB Quantum HDD, "8GB" HP SATA SSD adapted to IDE (Windows 98 SE)
Asus M32AD - Intel i3-4170, 8GB DDR3, 250GB Seagate 2.5" HDD (converting to SSD soon), EVGA GeForce GTS 250, OEM 350W PSU (Windows 10 Core)
*Haswell Tower* https://pcpartpicker.com/list/3vw6vW (Windows 10 Home)
*ITX Box* - https://pcpartpicker.com/list/r36s6R (Windows 10 Education)
Dell Dimension XPS B800 - Pentium 3 800Mhz, RDRAM
In progress projects:
*Skylake Tower* - Pentium G4400, Asus H110
*Trash Can* - AMD A4-6300
*GPU Test Bench*
*Pfsense router* - Pentium G3220, Asrock H97m Pro A4, 4GB DDR3
https://linustechtips.com/topic/995039-pc-upgrade-help/#findComment-11967122
What is your location? Also would you happen to know the model of your PSU? If it's a lower quality PSU I'd recommend getting a new one (obviously if it's good then it's fine).
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
https://linustechtips.com/topic/995039-pc-upgrade-help/#findComment-11967124
i live in Germany, and i don't know what my PSU is right now, but i think it was decent.
https://linustechtips.com/topic/995039-pc-upgrade-help/#findComment-11967131
the case seems like it would be good, and no i dont plan on overclocking, so the stock cooler it is, thank you.
https://linustechtips.com/topic/995039-pc-upgrade-help/#findComment-11967134
6 minutes ago, MandoPanda said:
thank you for taking the time and making an entire list but i definitely want to atleast get an ryzen 7 2700x
https://linustechtips.com/topic/995039-pc-upgrade-help/#findComment-11967136
3 minutes ago, wONKEyeYEs said:
Now I must admit that for my personal PCs I do lean heavily on aesthetics when I choose my case.
And I spend a little more than $40.
But damn, that case is ugly.
And I imagine all those drive bays might cut down on air flow.
Esp with only 2x120mm front and 1x120mm rear.
Are you talking about the Corsair I suggested? I have one right now and the airflow is adequate, especially considering that I have a R5 2600x and a 1070 with all drive bays full. CPU stays below 70C and GPU stays around 65C in low ambient and 70C max with a high ambient temp (These are temps while gaming for around 45min to an hour).
*GPU Test Bench*
https://linustechtips.com/topic/995039-pc-upgrade-help/#findComment-11967169
Also, you said you have storage.
So that's 110 toward the 7 2700x .
But, yeah, I'd bite the bullet and go for a new PSU.
as long as the temperatures dont get too high i dont mind bad airflow, and yeah i dont care how the case looks really.
what wattage should the PSU be?
https://linustechtips.com/topic/995039-pc-upgrade-help/#findComment-11967174
Keep in mind that the 2700x is half of your budget...
Are you planning on overclocking? If so, get the 2700 because they perform the same when you overclock.
Dedicating half of your budget makes it tough to make a well balanced build... but here it goes...
Again... This is really really REALLY not a good idea... But this is what you are looking at when you want to dedicate half of your budget to one component...
Rest In Peace my old signature...                  September 11th 2018 ~ December 26th 2018
https://linustechtips.com/topic/995039-pc-upgrade-help/#findComment-11967584
i already decided what i get but thank you, i dont really need a memory or storage upgrade.
thats what i got
AMD - Ryzen 7 2700X 3.7 GHz 8-Core Processor
Gigabyte - X470 AORUS ULTRA GAMING ATX AM4 Motherboard
Corsair - SPEC-ALPHA (White/Red) ATX Mid Tower Case
Corsair TX650M PC-Netzteil (Voll-Modulares Kabelmanagement, 80 Plus Gold, 650 Watt, EU)
https://linustechtips.com/topic/995039-pc-upgrade-help/#findComment-11967601
