Audio Setup help and recomendations
Hi, My current setup is coming to an end, and i want to upgrade it.
What I want from a audio system is to switch from headphones to speaker without changing software settings. currently my speakers have a physical volume control with a headphone and mic. jack, which switches to headphones when i plug them in. I would like to continue to have this flexibility, maybe without plunging them in and out but via a switch. However, I do not really know my way around the required hardware i would need for this. I do not have a dedicated soundcard but use the on-board one. Quality is an issue to me but it must not be high end, but rather decent middle class.
Thanks for any tips, recommendations
https://linustechtips.com/topic/994703-audio-setup-help-and-recomendations/
Usually even if you have both the headphones and speakers plugged just into a 3.5mm jack, you can switch between the two by right-clicking on sound in the bottom right tray > sound settings > select which ever you want.
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
Ok let me specify: I am looking for a complete solution: Speakers, and headphones and a whatever hardware I require to achieve above. My budget is not yet decided but not to tight.
---EDIT---
Optionally a 1/4 inch jack for the headphones
