you won't be getting much of an overclock with both the cooler and mobo. get a locked i7 8700 and good B360/H370 board instead, use the money saved on the CPU for a better case/PSU.
https://linustechtips.com/topic/994172-new-builder-need-help/#findComment-11959355
No.  THere are better coolers out there, but people like to meme.  I wouldn't go with an 8700k at current prices, however.  I would get a 2600 and a b450 board, and put the saved $300 into upgrading your GPU to 2080ti.  That hyper 212 will let you OC the 2600 to 4.2 no problem.
I edit the shit out of my posts.  Refresh before you respond.
https://linustechtips.com/topic/994172-new-builder-need-help/#findComment-11959358
The 8700 is literally an overpriced 2600(after OC).   See past you goytel blinders.
https://linustechtips.com/topic/994172-new-builder-need-help/#findComment-11959361
Not having an SSD in high end gaming PCs should be a sin, good that you added one
and yes, that mobo and cooler is no good for overclocking. Expect spending extra $100 on the motherboard and $70 on the cooler for 5ghz overclock attempt.
Desktop benching:
https://linustechtips.com/topic/994172-new-builder-need-help/#findComment-11959373
Right, it's not like they're using completely different architectures or anything...
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/994172-new-builder-need-help/#findComment-11959377
https://cpu.userbenchmark.com/Compare/Intel-Core-i7-8700-vs-AMD-Ryzen-5-2600/3940vs3955
Compare the OC'd 2600 scores to the base 8700 scores (which is accurate since the 2600 can OC on a $50 b350 board whereas intels need $110+ mobos to OC)
https://linustechtips.com/topic/994172-new-builder-need-help/#findComment-11959380
Even still the 2600 is faster; also the 2600 OCed scores are probably past 4 ghz and I don't think the stock cooler could reasonably push past 4ghz.
The 2600 is probably better value but that doesn't mean it's always the better choice. Sometimes the extra single threaded speed or lower core-core and memory latency of the i7 may be beneficial to certain workloads and allow it to outperform the 2600 and even the 2700.
Also I wouldn't really recommend OCing a 2600 on $50 B350 boards as the VRMs are not good... Usually I'd at least recommend a $70 board with decent VRMs if someone wants to OC
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/994172-new-builder-need-help/#findComment-11961223
ASRock Pro4 has great VRMs for the money.
https://linustechtips.com/topic/994172-new-builder-need-help/#findComment-11962117
I didn't notice the micro atx pro 4 is that cheap, my b. If you want an ATX board though the pro4s are over $70
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/994172-new-builder-need-help/#findComment-11962898
