Two M.2 SSDs...
Go to solution Solved by Electronics Wizardy,
Won't affect the gpu, the m.2 ssds use the pcie lanes from the chipset.
Hello all,
I've looked around on the forums for an answer but I can't seem to get a straight answer so I'll ask it here.
I currently have a Z370 Hero Maximus motherboard paired with a 8700k, If I were to get a NVME ssd and put it in one of the two m.2 slots and use PCIE x4 would that take away performance from the GPU?
IF it doesn't... Would adding another m.2(total of two m.2 ssds) affect the gpu performance then?
Really confused on all of this CPU lanes and whatnot.
Any help would be appreciated. Thanks!
https://linustechtips.com/topic/993741-two-m2-ssds/
