Pc start up issues
Solved by gbergeron,
42 minutes ago, Tseriesboi said:So I have an old gaming rig that I upgraded 2 years ago
Specs:
i7 2600
Leadtek gtx 1060
gigabyte h67ma-usb3-b3
16GB ram 1333mhz
1TB hhd
Cooler master extreme power plus 550w
It ran pretty much fine for the past 2 years until recently when i had problems booting up the pc. When i press the power button the phase led would all lit up and the all fans would spin for half a second. When I sent it to the repair shop it miraculously worked again. When I brought it home it worked fine until i shut it down. I couldn't start the pc and the same issues were occurring.
If your PSU is the same one that you bought originally with your build long time ago, good chance it is the issue.
