31 minutes ago, ElPorquito said:
Wouldn't I need a liquid cooler or a better air cooler if I wanted to overclock it?
The CPU or GPU? for the CPU not really, any $25 Hyper T4 or equal cooler will be fine for the CPU
the GPU cooler can already handle 1900mhz or better
