So I feel like doing something different.  Building a Sub $800 high refresh rate gaming PC utilizing 2xRX 470s.  Right now an RX 470 can be bought from Newegg for $110 brand new.  Add in an Overclocked I3-8350k, it might be possible!  I was gonna go Ryzen as I have an AM4 board, but the extra 500-700MHz will make a big difference trying to achieve 1080p 144Hz performance.  My only 2 questions is, does the RX 470 support mGPU Linked, and what DX12 games scale well with mGPU technology?
https://linustechtips.com/topic/993057-rx-470-mgpu/
RX 470 supports both Crossfire and DX12 mGPU.
Ashes of the singularity and Hitman games for sure. Not sure about Rise of the tomb raider (but shouldnt be as good as the other two)
Desktop benching:
https://linustechtips.com/topic/993057-rx-470-mgpu/#findComment-11949312
What do you mean by this?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/993057-rx-470-mgpu/#findComment-11949414
4 minutes ago, Snaeb said:
Intel and AMD are near equal in single threaded performance, but the extra speed scales well.
"Single threaded performance" is a combination of clock speed, instructions per clock, and instruction sets. Intel actually has quite a large single threaded advantage, but you can't compare clock speeds Apples to Apples because the microarchitectures are different.
Also, ryzen can be overclocked.
Primary PC:
PSU tier list
https://linustechtips.com/topic/993057-rx-470-mgpu/#findComment-11949487
From extensive testing, Intel and AMD are nearly tied in raw single threaded performance at the same speed.  However Intel has a clock speed advantage with a much higher ceiling.  My 2700x at 4.3GHz matches an 8700k if all cores are at 4.3GHz as well.
https://linustechtips.com/topic/993057-rx-470-mgpu/#findComment-11949558
