Hi, this is a follow up from this thread:
After getting some advice I have adjusted my build and just wanted some final feedback, I'm going to order the parts this evening.
Only thing to note is I am on the fence about the CPU cooler. I want the build to have a e s t h e t i c as it will be on show in my gaming room, but at this stage thats about it as I won't be overclocking to begin with so I may decide to go without. Stock coolers just look really ugly.
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor  (£143.86 @ Aria PC)
CPU Cooler: NZXT - Kraken X62 Rev 2 98.2 CFM Liquid CPU Cooler  (£129.98 @ Box Limited)
Motherboard: MSI - B450 TOMAHAWK ATX AM4 Motherboard  (£99.59 @ Amazon UK)
Memory: Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory  (£129.98 @ CCL Computers)
Storage: Samsung - 860 Evo 500 GB 2.5" Solid State Drive  (£69.99 @ Aria PC)
Video Card: EVGA - GeForce RTX 2070 8 GB Black Video Card  (£510.79 @ Overclockers.co.uk)
Case: NZXT - H500 (White) ATX Mid Tower Case  (£69.59 @ Aria PC)
Power Supply: EVGA - SuperNOVA G3 550 W 80+ Gold Certified Fully-Modular ATX Power Supply  (£85.47 @ Scan.co.uk)
Total: £1239.25
Generated by PCPartPicker 2018-11-08 18:49 GMT+0000
|| Processor: AMD Ryzen 5 2600 || RAM: 32GB (4x8GB) Corsair DDR4 Vengance (3000) || Motherboard: ASUS Prime B450-Plus || Graphics Card: Gigabyte RTX2070 || Storage: 750GB SSD (2 Drives), 3TB HDD (2 Drives) || Case: NZXT H500 || Power Supply: be quiet! Pure Power 11 600W ||
https://linustechtips.com/topic/992569-adjusted-build-after-advice/
Seems decent to me. Should look good too.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
Just watched a video on the case, turns out that cooler won't really fit so I am going to leave out the cooler for now and just use a stock one and when I want to OC I will buy a better cooler then.
Stock AMD cooler is great, you'll probably want to upgrade to a decent air cooler to overclock if there's trouble with a radiator.
Primary PC:
PSU tier list
How many watts do I need?
Why spend £130 on a cooler if you are not overclocking ?
This would be a better way to go. Drop the AIO for a good air cooler and slap an 8 core in with the savings.
CPU: AMD - Ryzen 7 2700 3.2 GHz 8-Core Processor  (£250.36 @ Aria PC)
CPU Cooler: ARCTIC - Freezer 33 eSports Edition (Black/White) CPU Cooler  (£39.95 @ Amazon UK)
Power Supply: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply  (£64.99 @ CCL Computers)
Total: £1235.24
Generated by PCPartPicker 2018-11-08 22:38 GMT+0000
