Will this affect audio quality?
Solved by dizmo,
Thanks for the detailed reply, I'll also order this one from america (it'll take a few weeks to arrive) and in the mean time order and use the previous one as it seems to be the only one I can get here. Hopefully it won't be too bad!
That one looks pretty perfect. I just find thicker cables last longer, kink less, etc.
It's cheap too! Provided they don't try and bend you over on the shipping.
