specs
GT 1030
i3 3240
8gb ram
i was playing gta 5 earlier and out of now where my fps dropped to 2 5 7 2 then went back up to 30-70 fps and i was so confused until it happened again and again
i  don't know what it could be as my pc has not done this before so what should i do and what could it be
https://linustechtips.com/topic/991159-massive-lag-spikes/
Do you have any programs running in the background, such as web browser windows open? Closing programs you're not using may help.
Try running MSI Afterburner to show the on screen display so you can see your RAM, GPU usage and CPU usage when the FPS drops happen.
What graphical settings are you playing the game at? What are the results if you run the built in benchmark? (the benchmark results are stored in a text file in the Documents/Rockstar Games/GTA V/Benchmarks folder.
https://linustechtips.com/topic/991159-massive-lag-spikes/#findComment-11931147
Nope skype and steam and the ram usage wasn't even that high
https://linustechtips.com/topic/991159-massive-lag-spikes/#findComment-11931150
1 minute ago, Mattk13 said:
its a week old install  i haven't really downloaded much and windows would tell me if there was any malware like cause i am running windows 10
Not really Windows 10 is not special and gets plenty of malware without warning the user. And ive known people who manage to pretty much instantly get malware on a new install. If its connected to the internet and youve been on pretty much any website, theres a chance. Might be small but its worth ruling out easy stuff first.
So Id start this whole troubleshooting like i start every troubleshooting: scan for malware. You eliminate that then you move onto things like corrupted drivers or failing hardware.
https://www.malwarebytes.com enable rootkit scanning and do a threat scan.
If no malware, get the latest Nvidia drivers and do a clean install(its an option under custom installation).
Tbh those specs are pretty low end for GTA5, which can chew up both CPU and GPU resources and tons of GPU RAM.
Is the PC overheating and throttling?
https://linustechtips.com/topic/991159-massive-lag-spikes/#findComment-11931169
the latest nvidia drivers kill performance i am running the oldest driver you can get
and no its not low end for gta it beats the requirements in single player high settings i usally get 60 fps avg
https://linustechtips.com/topic/991159-massive-lag-spikes/#findComment-11931173
Whats this about the latest drivers killing performance????
https://linustechtips.com/topic/991159-massive-lag-spikes/#findComment-11931181
Nvidia drivers kill performance
look it up dude i literally reinstalled windows so i could use the older drivers and my fps was alot better as i would get like 20-50 fps now i get 40-80
https://linustechtips.com/topic/991159-massive-lag-spikes/#findComment-11931183
Newer drivers IMPROVE performance, I don't know what you're smoking but it improves my experience when I update
https://linustechtips.com/topic/991159-massive-lag-spikes/#findComment-11931191
Just now, Aprilfooldude said:
Plus a GT 1030 will have significant issues with specific times and/or scene changes in GTA V. I have a GTX 1050 Ti and I still notice big drops during the day and when I am moving fast.
usally that doesn't happen to me its very smooth most of the time
https://linustechtips.com/topic/991159-massive-lag-spikes/#findComment-11931205
Im using the october 11 release drivers. Pretty sure the performance issues were from the drivers right when the RTX was released.
https://linustechtips.com/topic/991159-massive-lag-spikes/#findComment-11931213
usally it wouldn't be anywhere but it starter when i was near the LS Customs
near the diamond store
It could be that windows is trying to do background tasks, I don't see how it could be anything else. But to be honest you hardware isn't the best for gaming anyways. A 1030 was designed for light loads like an HTPC setup more than an intensive load like GTA
https://linustechtips.com/topic/991159-massive-lag-spikes/#findComment-11931223
i came from a Intel hd 2500 so anything that gets console performance is great to me
https://linustechtips.com/topic/991159-massive-lag-spikes/#findComment-11931227
